Ethernet Products
5707 Discussions
[Intel XXV710] Firmware Upgrade - Failed? No longer detected?
JamesAA
I have a XXV710-DA2. I am running Ubuntu 24.04.
I attempted to update the firmware. On the fist run nvmupdate64e was VERY slow to detect but when it did it said firmware update available.
I walked away and let it run, when i came back it looked like it had completed.
However, after I've rebooted it is no longer detected in lspci, nothing in dmesg.
nvmupdate64e is not saying no device detected.
Have I some how bricked this device? Is there anyway to recover it?
Ugh!! Please help!!
thanks!!
HienNguyen
I have the same problem.
However my card is XL710-Q10CP. I think  the updater had problems with ubuntu 24.04, I did update multiple cards with ubuntu 22.04 and everything is ok.
Now the card is blank. I think we need another tools to reflash firmware again.
JamesAA
So that means your card is also now "defective" right? You are unable to use it ?
HienNguyen
Yes, the card's firmware was cleared and unable to use.
After searching, we may need lanconf64e tool and firmware to re-flash the card.
https://community.intel.com/t5/Ethernet-Products/Configuring-a-blank-X710/td-p/1593965
JamesAA
Hmm i am not sure that will work for me as i cannot even see it coming up as en ethernet controller in lspci? does yours show?
Did you get access to the lanconf64e + any instructions?
HienNguyen
Here is my lspci
03:00.0 Ethernet controller: Intel Corporation Device 154b (rev 02)
03:00.1 Ethernet controller: Intel Corporation Device 154b (rev 02)
03:00.2 Ethernet controller: Intel Corporation Device 154b (rev 02)
03:00.3 Ethernet controller: Intel Corporation Device 154b (rev 02)
The card still show but the name is not the same.
Here is my nvmupdate64e
No, I hope Intel can send us.
JamesAA
Ah ok, have you contacted their support or you are hoping this see this thread?
HienNguyen
I am very lucky, after turn off server and re-seat the card as some other thread suggest, the card had rollback to previous firmware.
For me the original firmware is 6.0.1. I will try to upgrade version by version with ubuntu 20.04 and report back.
HienNguyen
Upgrade success path: 6.01 -> 6.8 --> 7 --> 7.3 --> 8 --> 8.7 --> 9.0 --> 9.52.
