Ethernet Products
5566 Discussions
Intel i210 driver for Windows 2003
hshen7
Dear,
How can I210 work under windows 2003 as I210 no support this OS? Thanks.
st4
New Contributor III
Hi Fishersz,
Yes, I210 network adapter does not support Windows 2003 as you may refer to http://www.intel.com/support/network/adapter/i210t1server/sb/CS-034399.htm Intel® Ethernet Server Adapter I210-T1 — Operating System Support for Intel® Ethernet Server Adapter I210 Series.The final release of Windows 2003 driver for Intel network adapter is available at https://downloadcenter.intel.com/detail_desc.aspx?agr=Y&DwnldID=18719 Intel® Download Center, however I210 is not supported.
rgds,
wb
st4
New Contributor III
Hi Fishersz,
Yes, I210 network adapter does not support Windows 2003 as you may refer to http://www.intel.com/support/network/adapter/i210t1server/sb/CS-034399.htm Intel® Ethernet Server Adapter I210-T1 — Operating System Support for Intel® Ethernet Server Adapter I210 Series. The final release of Windows 2003 driver for Intel network adapter is available at https://downloadcenter.intel.com/detail_desc.aspx?agr=Y&DwnldID=18719 Intel® Download Center, however I210 is not supported.
rgds,
wb
st4
New Contributor III
Hi Fishersz,
Yes, I210T network does not support Windows 2003 http://www.intel.com/support/network/adapter/i210t1server/sb/CS-034399.htm Intel® Ethernet Server Adapter I210-T1 — Operating System Support for Intel® Ethernet Server Adapter I210 Serie
The final release of Windows 2003 driver is available at https://downloadcenter.intel.com/detail_desc.aspx?agr=Y&DwnldID=18719 Intel® Download Center however I210-T1 is not supported.
thanks,
wb
