Ethernet Products
5821 Discussions
Intel i210IT giving PCIe bus errors - CentOS 7
DMunr2
Ref: Intel i210IT
When I try to install Centos Linux v7 on this system, I'm getting a flood of errors.
After a lot of time fault finding, there seems to be a recurring PCIe bus error, see extract below.
Base System: Intel Core i7 6820EQ (Skylake) CPU with 16Gb DDR4 RAM
Same issue with Ubuntu 16.04 LTS.
Any driver update?
[ 2112.007218] pcieport 0000:00:1d.2: AER: Corrected error received: id=00ea
[ 2112.007224] pcieport 0000:00:1d.2: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=00ea(Receiver ID)
[ 2112.007226] pcieport 0000:00:1d.2: device [8086:a11a] error status/mask=00000001/00002000
[ 2112.007227] pcieport 0000:00:1d.2: [ 0] Receiver Error
[ 2112.011256] pcieport 0000:00:1d.2: AER: Corrected error received: id=00ea
[ 2112.011263] pcieport 0000:00:1d.2: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=00ea(Receiver ID)
[ 2112.011266] pcieport 0000:00:1d.2: device [8086:a11a] error status/mask=00000001/00002000
[ 2112.011267] pcieport 0000:00:1d.2: [ 0] Receiver Error
[ 2112.013527] pcieport 0000:00:1d.2: AER: Corrected error received: id=00ea
[ 2112.013534] pcieport 0000:00:1d.2: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=00ea(Receiver ID)
[ 2112.013536] pcieport 0000:00:1d.2: device [8086:a11a] error status/mask=00000001/00002000
[ 2112.013538] pcieport 0000:00:1d.2: [ 0] Receiver Error (First)
[ 2112.015510] pcieport 0000:00:1d.2: AER: Multiple Corrected error received: id=00ea
[ 2112.015580] pcieport 0000:00:1d.2: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=00ea(Receiver ID)
[ 2112.015582] pcieport 0000:00:1d.2: device [8086:a11a] error status/mask=00000001/00002000
[ 2112.015584] pcieport 0000:00:1d.2: [ 0] Receiver Error
[ 2112.015586] pcieport 0000:00:1d.2: Error of this Agent(00ea) is reported first
[ 2112.015593] pcieport 0000:05:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0500(Transmitter ID)
[ 2112.015595] pcieport 0000:05:00.0: device [10b5:8605] error status/mask=00001081/0000e000
[ 2112.015596] pcieport 0000:05:00.0: [ 0] Receiver Error
[ 2112.015598] pcieport 0000:05:00.0: [ 7] Bad DLLP
[ 2112.015600] pcieport 0000:05:00.0: [12] Replay Timer Timeout
[ 2112.017189] pcieport 0000:00:1d.2: AER: Corrected error received: id=00ea
[ 2112.017197] pcieport 0000:00:1d.2: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=00ea(Receiver ID)
[ 2112.017201] pcieport 0000:00:1d.2: device [8086:a11a] error status/mask=00000001/00002000
[ 2112.017204] pcieport 0000:00:1d.2: [ 0] Receiver Error
[ 2112.022836] pcieport 0000:00:1d.2: AER: Corrected error received: id=00ea
[ 2112.022842] pcieport 0000:00:1d.2: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=00ea(Receiver ID)
[ 2112.022844] pcieport 0000:00:1d.2: device [8086:a11a] error status/mask=00000001/00002000
[ 2112.022846] pcieport 0000:00:1d.2: [ 0] Receiver Error (First)
Hi Donatell018,
Thank you for posting in Wired Communities. I managed to check on the this website and there are similar issue which you can refer to below link, or you can contact the OS support (Ubuntu* and Centos*) for further investigation.
https://askubuntu.com/questions/771899/pcie-bus-error-severity-corrected https://askubuntu.com/questions/771899/pcie-bus-error-severity-corrected (Please note: this is third party website, the content of this site is not within Intel control)
We do not have Ubuntu and Centos driver available on our download website, you may refer to https://downloadcenter.intel.com/product/64402/Intel-Ethernet-Controller-I210-IT Downloads for Intel® Ethernet Controller I210-IT
Can you share where did you obtain the driver from?
By the way, What is the brand and model of the system this I210-IT ethernet controller embedded on? Will you be encountering this error if using Windows OS?
Sharon T
Hi Donatell018,
Please feel free to provide the information for us to further check.
Sharon T
