Ethernet Products
5821 Discussions
Intel i210it and fiber optical channel
ETsar
Hello! I have an intel i210 and EEPROM Winbond 25Q16. I want to configure the controller to work with the optical module Optocore OTB1250-3520. I configured EEPROM in Fiber mode, writing 0x1536 to a memory location. My optical module is not working. I set SFP module. He is working! Prompt how to make it work Optocore optical module? I am sorry for my bad English. Attaches datashits and waveform!
Also, I have a working module Optokore and its waveform.
Thank you!
ETsar
The rest of the waveform!
VincentT_T_Intel
Hi Tsarevsky, we're currently checking your inquiry, will share update as soon as possible.
CARL_W_Intel
The Intel(r) Ethernet Controller I210-IT is a 1000BASE-T device only. There is no way to connect to an SFP device.
You will need to use the Intel(r) Ethernet Controller I210-IS, which supports SerDes/SGMII to SFP devices. http://ark.intel.com/products/64401/Intel-Ethernet-Controller-I210-IS Intel® Ethernet Controller I210-IS Specifications
