Ethernet Products
5376 Discussions
Intel x520 Data Transfers
MMich19
After speaking with an Intel rep this NIC does not have a built in DMA engine.
Does it provide some other data transfer mechanism that allows for programming the controller to specify source address, destination address, and buffer size (i.e., # bytes)
to selectively xfer large chunks of data using the x520 resources without impacting CPU performance?
SYeo3
Valued Contributor I
Dear maminsb,
Thank you for contacting Intel.
You may explore the different advance options available for our 10 Gigabit Adapters for large send offloads.
http://www.intel.com/support/network/adapter/pro100/sb/CS-029402.htm Intel® Server Adapters — Advanced Driver Settings for Intel® Ethernet 10 Gigabit Server Adapters
Hope this helps.
Sincerely,
Sandy
