Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Intel x520-T2 DCB problem
Hello.
I cann't set dcb on mode from dcbtool in CentOs 7.
lldpad daemon is running.
Kernel is compiled with "CONFIG_DCB=y" flag.
Some ethtool information.
# ethtool -i enp1s0f0
driver: ixgbe
version: 4.4.6
firmware-version: 0x80000389
bus-info: 0000:01:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
# ethtool -k enp1s0f0
Features for enp1s0f0:
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: on
tx-checksum-ip-generic: off [fixed]
tx-checksum-ipv6: on
tx-checksum-fcoe-crc: on [fixed]
tx-checksum-sctp: on
scatter-gather: on
tx-scatter-gather: on
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: on
tx-tcp-segmentation: on
tx-tcp-ecn-segmentation: off [fixed]
tx-tcp6-segmentation: on
udp-fragmentation-offload: off [fixed]
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: off
rx-vlan-offload: on
tx-vlan-offload: on
ntuple-filters: off
receive-hashing: on
highdma: on [fixed]
rx-vlan-filter: on [fixed]
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: on [fixed]
tx-gre-segmentation: off [fixed]
tx-ipip-segmentation: off [fixed]
tx-sit-segmentation: off [fixed]
tx-udp_tnl-segmentation: off [fixed]
tx-mpls-segmentation: off [fixed]
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off [fixed]
rx-all: off [fixed]
tx-vlan-stag-hw-insert: off [fixed]
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: off [fixed]
busy-poll: on [fixed]
Some dcbtool information.
# dcbtool sc enp1s0f0 dcb on
Command: Set Config
Feature: DCB State
Port: enp1s0f0
Status: Successful
# dcbtool gc enp1s0f0 dcb
Command: Get Config
<span style="font-family: 'courier new', courier;"...
Highlighted
Community Manager
Hi N2o,
Thank you for the post. Let me check on this, will update you if there is any finding.
rgds,
wb
Highlighted
Community Manager
Hi N2o,
Good day. Further checking you need to contact resource design center http://www.intel.com/content/www/us/en/design/servers/server-design-center.html
or other Linux forums like sourceforge for them to better assist you.
rgds,
wb
Highlighted
Hi, I meet same problem. How do you fix it?
