Using Ubuntu 18.04.
Asus X299 with Intel X550-T2 onboard
I am having an issue with this particular machine auto negotiating 10Gb. The onboard LOM will only negotiate to 1Gb. If I run `ethtool -s <device> advertise 0x1000`, the machine will delink and then negotiate to 10Gb and work as expecting. Rebooting the machine (or unplugging network cable) will cause it to negotiate to 1G again resulting in having to run the ethtool command again.
This is what I have tried:
Tried different cable from confirmed working machine that auto negotiates to 10Gb.
Tried upgrading ixgbe driver to latest (5.5.3)
Tried upgrading X550 firmware.
I put an Intel x540-T1 card in the machine and that card works properly and negotiates to 10Gb automatically. Move the cable to the LOM x550, and it still negotiates to 1Gb.
I also tried loading a live version of Fedora 29 (Kernel 4.18) with same exact symptoms.
We have several other machine negotiating fine on the same exact switch. I have tried those cables to test this problematic machine with same result as above.
We have a machine that is pretty similar in hardware that is not exhibiting this issue. It is an ASUS x99 motherboard, with the same LOM Intel x550 card, running on 16.04.
The machine that is causing problems is an Asus x299 motherboard with the Intel x550 LOM card running 18.04 (16.04 won't work on the x299 chipset for some reason). I have a suspicion that it could potentially be related to the x299?
The only way I have been able to get this problematic machine to negotiate to 10Gbps automatically is by plugging a cable directly from the LOM x550 of the problematic machine to another machines 10Gb network card. Doing that, the problematic machine will negotiate properly to 10Gb.
I'm trying to find another 10Gb switch to test with to see if it could be unique to this combination of switch and machine. However, I'm reluctant to blame it on the switch since we have about several other machine working perfectly fine on the switch (some with the same exact x550 LOM).
Other notes:
The switch is a Cisco Nexus 3172TQ. We are using CAT6 cable.
I didn't see any errors. Yes I have tried the in-kernel driver that came with 18.04, I upgraded the driver to 5.5.3 in 18.04 (just to test). I also use the Fedora 29 in-kernel driver (don't remember which version is included though). So in the serverfault thread I mentioned the transfer speed was 1Gbps, but that was when I forced the speed to be 10Gb and not letting the card autonegotiate to 10Gbps with the advertise command.
The point-to-point will negotiate automatically to 10Gbps. The link will be green in this case.
In all other cases when it negotiates to 1Gbps it will be amber in color.
ethtool -k <interface> and ethtool -i <interface> are below.
driver: ixgbe
version: 5.5.3
firmware-version: 0x80000d04
expansion-rom-version:
bus-info: 0000:b3:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
Features for enp179s0f0:
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: off [fixed]
tx-checksum-ip-generic: on
tx-checksum-ipv6: off [fixed]
tx-checksum-fcoe-crc: on [fixed]
tx-checksum-sctp: on
scatter-gather: on
tx-scatter-gather: on
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: on
tx-tcp-segmentation: on
tx-tcp-ecn-segmentation: off [fixed]
tx-tcp-mangleid-segmentation: off
tx-tcp6-segmentation: on
udp-fragmentation-offload: off
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: off
rx-vlan-offload: on
tx-vlan-offload: on
ntuple-filters: off
receive-hashing: on
highdma: on [fixed]
rx-vlan-filter: on
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: on [fixed]
tx-gre-segmentation: on
tx-gre-csum-segmentation: on
tx-ipxip4-segmentation: on
tx-ipxip6-segmentation: on
tx-udp_tnl-segmentation: on
tx-udp_tnl-csum-segmentation: on
tx-gso-partial: on
tx-sctp-segmentation: off [fixed]
tx-esp-segmentation: off [fixed]
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off [fixed]
rx-all: off
tx-vlan-stag-hw-insert: off [fixed]
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: off [fixed]
l2-fwd-offload: off [fixed]
hw-tc-offload: off
esp-hw-offload: off [fixed]
esp-tx-csum-hw-offload: off [fixed]
rx-udp_tunnel-port-offload: on
My next step was to get with ASUS support in parallel with this thread.
Working x99 motherboard output.
This system is running Ubuntu 16.04 (which is why you see older versions of the driver). I'm hesitant to make any changes to this x99 box as people are using it.
ethtool -i enp2s0f0
driver: ixgbe
version: 4.2.1-k
firmware-version: 0x80000573
bus-info: 0000:02:00.0
supports-test: yes
supports-priv-flags: no
~$ ethtool -k enp2s0f0
Features for enp2s0f0:
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: on
tx-checksum-ip-generic: off [fixed]
tx-checksum-ipv6: on
scatter-gather: on
udp-fragmentation-offload: off [fixed]
rx-vlan-offload: on
tx-vlan-offload: on
ntuple-filters: off
receive-hashing: on
highdma: on [fixed]
rx-vlan-filter: on [fixed]
tx-gre-segmentation: off [fixed]
tx-ipip-segmentation: off [fixed]
tx-sit-segmentation: off [fixed]
tx-udp_tnl-segmentation: off [fixed]
rx-fcs: off [fixed]
rx-all: off
l2-fwd-offload: off
busy-poll: on [fixed]
hw-tc-offload: off
Thanks. I’m trying to get ASUS support to answer my question. I’m linking them here with all of the content and debugging information in this thread but they haven’t gotten back with me.
Im sending another email today to try and get them.
I have and they are looking into the issue. They told me they would reply in 24-48 hours with an update.
Mike,
I heard back from ASUS and this is their response
ASUS Support Response:
I appreciate your patience and for giving us time to come up with a resolution for your case. After collaborating with our engineers we are now able to provide you with a recommendation on how to address your concern.
The motherboard only support WIndows 10 64 bit. Other OS, we do not have any software support. We do not have driver for Linux OS.
Please do contact Intel technical support to get the driver working.”
So based on their response, they do not support anything but Windows 10 (which I feel is a complete joke) these motherboards are targeted at machine learning people (supporting 4x gpus) yet the motherboard doesn’t support Linux, which is where a vast majority of the development is in the ML space.
But I digress, so at this point ASUS is pointing the finger back to Intel saying Intel should fix your driver on Linux. Unfortunately, I’m in the middle of it.
What is your recommendation at this point?
Thsts completely understandable.
Just curious, where are you finding the ETrackID information? Did I miss it?
Nope! I appreciate it. You can close the ticket if you need.
