Ethernet Products
5821 Discussions
Interrupt status failed
Sava30
I started the hardware test from Intel and got the message Interrupt Status Failed. Is that normal or does one have to fix it. What does the interrupt status stand for? Can someone help me?
Interrupt Status : Failed
AlHill
Run :  https://www.intel.com/content/www/us/en/download/15951/19792/intel-processor-diagnostic-tool.html
and report back.
[Windows 11 is the new Vista]
Sava30
AlHill
What "Intel" tool did you run to get the failed message?
Sava30
I used the Intel Pro Set Adapter Utility and ran the hardware test
Wired_driver_26.4_x64.zip
Caguicla_Intel
Hello Sava30,
We are sorry to hear that you are facing Interrupt status failed issue on your Ethernet. For us to further check the issue, please provide the following details.
1. Brand and model of your motherboard
2. Exact Operating System used
3. Do you use the same 26.4 version for PROSet and driver for your Intel Ethernet I219-V?
4. Do you encounter performance issue on your Ethernet or how does the Interrupt status failed affects the performance on your Ethernet?
We will follow up after 3 business days in case we don't hear from you.
Crisselle C.
Intel® Customer Support
Caguicla_Intel
Hello Sava30,
Good day!
This is just a follow up message for the information we requested for us to continue checking your query.
Hoping to hear from you soon.
Should there be no reply, we will follow up after 3 business days.
Crisselle C.
Intel Customer Support
Caguicla_Intel
Hello Sava30,
How are you doing?
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
Crisselle C.
