Ethernet Products
4359 Discussions
Is X540-T2 compatibe with HP DL380G7?
I know the X520-T2 work with this server. Looking at the X540 spec, I think it should work. Has anyone use the X540-T2 with the HP DL380G7?
Hi TranFamily35,
Thank you for posting in Wired Ethernet Community.
To ensure compatibility, suggest to check out the HP option part list for tested 10GbE Ethernet Adapter on your HP DL380G7.
http://h20565.www2.hpe.com/hpsc/doc/public/display?docLocale=en_US&docId=emr_na-c02755440&sp4ts.oid=59101# N10895
Hope this helps.
regards,
Vince
Hi TranFamily35,
We'd like to check if you still have additional query regarding Intel X540-T2.
regards,
Vince
