Ethernet Products
5821 Discussions
Issue with Intel E810 NIC: Unexpected Behavior with PHY Sync Commands
Aber1
I've been working with the Intel E810-XXVDA4T NIC and have come across an unexpected behavior that I'd like to discuss and seek assistance on.
Setup:
Linux 5.11.22-100.fc32.x86_64
NIC: Intel E810
driver: ice
version: 1.12.6
firmware-version: 4.20 0x8001778b 1.3346.0
expansion-rom-version:
bus-info: 0000:01:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
Issue:
When I execute the following commands:
echo 1 0 > /sys/class/net/enp1s0f1/device/phy/synce
I got:
and
echo 0 0 > /sys/class/net/enp1s0f0/device/phy/synce
I got:
I observe that the pin gets closed. This behavior is unexpected, especially since enp1s0f1 and enp1s0f0 are not on the same bus.
Expected Behavior: Given that the two commands are addressing different buses, I would expect that the actions on one bus would not affect the other.
Question:
Is there a known reason for this behavior?
Any insights or suggestions would be greatly appreciated. Thank you in advance for your assistance!
Aviad
Yogaeasvaran
Greetings Avi,
Thank you for contacting Intel Customer Support.
May I know if you are trying to run the PTP and PHY timers?
Besides, you can also refer to the E810 datasheet page 1444 Chapter 9.7
 https://cdrdv2.intel.com/v1/dl/getContent/613875?explicitVersion=true
If you have any further questions or queries, please kindly let us know.
Yogaeasvaran
Yogaeasvaran
Greetings Avi,
Regarding your case number 06005449, we are following up to find out if you were able to complete the actions, we previously recommended.
Please reply to this thread to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply!
Yogaeasvaran
Yogaeasvaran
Greetings Avi,
Yogaeasvaran
Yogaeasvaran
Greetings Avi,
Kindly note that as we have not received any response from our previous follow-ups, we will be closing this request.
If you have any more questions in the future, please don't hesitate to post a new question, as this thread will no longer be monitored.
Thank You & Regards
Yogaeasvaran
Intel® Customer Support
