Ethernet Products
5821 Discussions
Issue with X710 and XL710 on Dell PowerEdge server + RedHat 7.2
MElha1
Hi Intel comunity,
We have serious problem with intel cards (X710 and XL170).
The linux server (Dell Power Edge 630) don't see them completely under RedHat 7.2. I dont see the interfaces under linux ifconfig -a.
I have installed the last drivers (ixgbe-5.1.3 and i40e-2.0.26) but didnt succedded to update the firmware (if it is the problem).
Here below the output of my server:
  • From "modinfo" I get the following output:
[root@TBOS ~]# modinfo i40e
filename: /lib/modules/3.10.0-327.el7.x86_64/updates/drivers/net/ethernet/intel/i40e/i40e.ko
version: 2.0.26
license: GPL
description: Intel(R) 40-10 Gigabit Ethernet Connection Network Driver
author: Intel Corporation, <<a href="mailto:e1000-devel@lists.sourceforge.net">e1000-devel@lists.sourceforge.net>
rhelversion: 7.2
srcversion: F49696A466EC36F89F8FE86
alias: pci:v00008086d0000158Bsv*sd*bc*sc*i*
alias: pci:v00008086d0000158Asv*sd*bc*sc*i*
alias: pci:v00008086d000037D3sv*sd*bc*sc*i*
alias: pci:v00008086d000037D2sv*sd*bc*sc*i*
alias: pci:v00008086d000037D1sv*sd*bc*sc*i*
alias: pci:v00008086d000037D0sv*sd*bc*sc*i*
alias: pci:v00008086d000037CFsv*sd*bc*sc*i*
alias: pci:v00008086d000037CEsv*sd*bc*sc*i*
alias: pci:v00008086d0000374Csv*sd*bc*sc*i*
alias: pci:v00008086d00001588sv*sd*bc*sc*i*
alias: pci:v00008086d00001587sv*sd*bc*sc*i*
alias: pci:v00008086d00001589sv*sd*bc*sc*i*
alias: pci:v00008086d00001586sv*sd*bc*sc*i*
alias: pci:v00008086d00001585sv*sd*bc*sc*i*
alias: pci:v00008086d00001584sv*sd*bc*sc*i*
alias: pci:v00008086d00001583sv*sd*bc*sc*i*
alias: pci:v00008086d00001581sv*sd*bc*sc*i*
alias: pci:v00008086d00001580sv*sd*bc*sc*i*
alias: pci:v00008086d00001574sv*sd*bc*sc*i*
alias: pci:v00008086d00001572sv*sd*bc*sc*i*
depends: ptp,vxlan
vermagic: 3.10.0-327.el7.x86_64 SMP mod_unload modversions
parm: debug:Debug level (0=none,...,16=all) (int)
[root@TBOS ~]#
  • From ifconfig –a, we don't see the port at all !!!
  • When I want to update the firmware, I get
    • [root@TBOS Linux_x64]# ./nvmupdate64e
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.28.19.4
Copyright (C) 2013 - 2016 Intel Corporation.
WARNING: To avoid damage to your device, do not stop the update or reboot or power off the system during this update.
Inventory in progress. Please wait [*|........]
Num Description Ver. DevId S:B Status
01) Intel(R) Ethernet Converged Network 1572 00:004 Access error
Adapter X710
Tool execution completed with the following status: Device not found
Press any key to exit.
  • Dmesg output:
[root@TBOS ~]# dmesg| grep i4...
Hi MikaelE,
Thank you for posting at Wired Communities. Please send the screenshot of the serial number which can be found on the white sticker on the physical network card, with the format of the serial number is 15 alphanumeric + 6 alphanumeric + 6 digits - 3 digits.
sharon
Hi MikaelE,
Please feel free to provide the information.
regards,
sharon
