Ethernet Products
4873 Discussions
It takes about 2~3 seconds to make the interface in Up status, after "ip link set dev eth0 up"
mzhan017
Is this normal to make the link UP after 2~3 seconds? If this is abnormal, how to debug this kind of issue?
# ethtool -i acc
driver: ixgbe
version: 5.1.0-k-rh7.7
firmware-version: 0x80000838, 1.1446.0
expansion-rom-version:
bus-info: 0000:00:08.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
# lspci | grep 08
00:08.0 Ethernet controller: Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01)
Nov 21 09:41:12 b kernel: [ 30.456608] ixgbe 0000:00:08.0: registered PHC device on eth
Nov 21 09:41:12 b kernel: [ 30.558498] IPv6: ADDRCONF(NETDEV_UP): eth: link is not ready //bring the interface UP
Nov 21 09:41:12 b kernel: [ 30.625695] ixgbe 0000:00:08.0 acc: detected SFP+: 10
Nov 21 09:41:14 b kernel: [ 33.181222] ixgbe 0000:00:08.0 acc: NIC Link is Up 1 Gbps, Flow Control: None
Nov 21 09:41:14 qrms6-fw-b kernel: [ 33.182994] IPv6: ADDRCONF(NETDEV_CHANGE): eth: link becomes ready
Mark
Mike_Intel
Hello mzhan017,
I am just sending another follow up to check if you still have questions or clarifications.
If you need further assistance, please post a new question.
Thank you.
Michael L.
Intel Customer Support Technicians
Mike_Intel
Hello mzhan017,
For us to further check the issue, please provide the following details.
  1. Are you using a PCIe network card or onboard network card?
  2. If you are using onboard, please provide the brand and model of your board or system.
  3. If you are using a PCIe card, please send a photo on both sides of the card focusing on the markings.
  4. What is your OS?
  5. Can you share the link of the latest driver that you installed?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
mzhan017
Related info of lab:
HP server: ProLiant DL380 Gen9
Embedded "HP Ethernet 10Gb 2-port 560FLR-SFP+ Adapter"
Product Name: "665243-B21";
Assembly Number: 669281-001;
Serial Number: MYI7290690
[root@qrms6-host01 ~]# hostnamectl
Static hostname: qrms6-host01
Icon name: computer-server
Chassis: server
Machine ID: 809c9776623c42d883f1d3b12cfe393b
Boot ID: fbe84f5e2a9048ca808be616551c402d
Operating System: Red Hat Enterprise Linux Server 7.7 (Maipo)
CPE OS Name: cpe:/o:redhat:enterprise_linux:7.7:GA:server
Kernel: Linux 3.10.0-1062.12.1.el7.x86_64
Architecture: x86-64
[root@qrms6-host01 drivers]# rpm -qf ./net/ethernet/intel/ixgbe/ixgbe.ko.xz
kernel-3.10.0-1062.12.1.el7.x86_64
Mark
mzhan017
Hi Michael,
I have replied you.
But couldn't retrieve my reply in the page. Seems there is issue for the site of community.intel.com.
My email is: mark.zhang@nokia-sbell.com
Mark
Mike_Intel
Hello mzhan017,
Thank you for the update. I am really sorry to hear that but I can see your last post. Can you try to post your answer on the details that I requested below again? If you will have some issues again, please update us for me to inform the team who is managing the community website.
  4. What is your OS?
mzhan017
Chassis: server
Mark
mzhan017
Hi Michael,
Attached the Lab-info in picture.
Maybe there is some special chars in the info, that causes the reply wasn't saved by site.
Mark
Mike_Intel
Hello mzhan017,
Thank you for resending the information. According to the attached picture that you sent, you are using an onboard HP network card. By the way, is this working fine before or this has been the behavior of the card ever since? Have you tried contacting HP about this issue?
Michael L.
mzhan017
Hi Michael,
I haven't contact the HP support yet. Do you suggest?
The issue happened in a long time in our lab.
From your experience, is it normal to take 2~3 seconds to became UP?
Mark
Mike_Intel
Hello mzhan017,
If this working fine before, definitely there is something wrong. However, it is best to check this with HP if they adjusted the speed of connecting to the network or if they have fix for this. The network card is embedded on their board so they may or they can alter some settings or features if they want to.
Michael L.
Mike_Intel
Hello mzhan017,
I hope you are having a good day. I just want to check if you already tried contacting the manufacturer of the board for further support.
Michael L.
mzhan017
Michael,
I have open ticket to HP support. and waiting response from HP.
Thanks for your support.
Mark
Mike_Intel
Hello mzhan017,
Thank you for the update. Since you are now talking to HP regarding the issue. Do you still have clarifications regarding this thread?
Michael L.
Mike_Intel
Hello mzhan017,
I just want to check if you still have clarifications regarding this thread.
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 2 workings days. Thank you.
Michael L.
Mike_Intel
Hello mzhan017,
Thank you.
Michael L.
