Ethernet Products
5605 Discussions
Just need one port of X550-AT2, how to disable/hide the other port?
Cody_Kuo
Hi Sir,
X550-AT2 is a dual port device, but customers only use one port, the other port needs to be disabled and hidden.  For example, customer expect only one port present in Windows Device Manager. How can I do that? Do I need to modify NVM?
BR,
Cody
Cody_Kuo
Hi BY,
I pulled LAN1_DIS_N down to GND on other projects using the X550-AT2 and port 1 did disappear, as shown bellow.2w.PNG
Thanks for this forum and your help.
BR,
Cody
B_Y
Hi @Cody_Kuo,
Generally, you may need to disable 1 of the 2 LAN ports from Bios or in Debug mode and X550-AT2 is an ethernet controller.
Kindly provide the System Support Utility(SSU) log from 1 of the customer system, this will allow us to check your adapter details and configuration.
Following Help Guide for the Intel® System Support Utility: https://www.intel.com/content/www/us/en/support/articles/000008563/ethernet-products.html
Please include the following information if providing the log is not convenient:
1) Operating system, OS build of the system
2) The model of chassis
3) The model of motherboard
BY_Intel
Intel Customer Support
Cody_Kuo
Hi BY,
I'm designing a custom board, and X550-AT2 is LAN On Motherboard.
The schematic of X550-AT2 as below, just use Port 0 and let Port 1 floating.
So BIOS can disable and hide the port 1, and port 1 cannot be detected by lanconf?
(Below is just an example)
BR,
Cody
Cody_Kuo
Hi BY,
I think I can pull LAN1_DIS_N to low to disable port 1, right?
BR,
Cody
B_Y
Hi @Cody_Kuo,
You are right at the correct subject, you may also refer to the Intel® Ethernet Controller X550 Datasheet page# 152 (4.4.2 Overview).
We have a forum for those specific inquiries and you can post it to that forum as per link below so it can get answered in more detail.
Embedded Connectivity Forum:
https://community.intel.com/t5/Embedded-Connectivity/bd-p/embedded-networking-connectivity
BY_Intel
B_Y
Hi @Cody_Kuo,
This is just a follow up regarding the information we have shared in regards your inquiry. If you have additional questions or clarifications, feel free to let us know.
BY_Intel
B_Y
Hi @Cody_Kuo,
Please be informed that we will now close this request since we have provided right channel: Embedded Connectivity Forum in case you have further inquiries. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
BY_Intel
Cody_Kuo
Hi BY,
BR,
Cody
B_Y
Hi @Cody_Kuo,
Noted and thank you for sharing the outcome. Thank you again. Please be informed that we will now close this request since the resolution work accordingly.
BY_Intel
