Ethernet Products
5736 Discussions
KTI226LM S RKTT MSL
SHime
Is there info regarding MSL for KTI226LM S RKTT (MM# 99AFMX)? Thank you.
B_Y
Hi @SHime,
I hope this message finds you well. I am just sending a follow up if you have any questions from the previous post. If so, please let us know. Thank you.
BY_Intel
Intel Customer Support
B_Y
Hi @SHime,
Hope you are doing well, below is the information in regards Moisture Sensitivity Level (MSL) for the following ethernet product:
Intel® Ethernet Controller I226-LM - Ordering code: KTI226LM, Spec Code: SRKTT
-  Intel® Ethernet Controller I225/ I226 Datasheet we found Moisture lever 3 on page 40, further details will be on this article# 596659.
Note: Moisture Sensitivity Level (MSL) information is Intel Confidential, that are not otherwise publicly available can be accessed via system integrators / developers premier account, after CNDA process and approval. Therefore, Login is required to follow the recommendations in this article.
For more details please check following article in case an account has not been created from your side: How to Apply for an Intel® Resource and Documentation Center (RDC) and/or Intel® Developer Zone (Intel® DevZone) Account
I hope the following information helps to answer your questions.
BY_Intel
B_Y
Hi @SHime,
BY_Intel
B_Y
Hi @SHime,
Please be informed that we will now close this request since you have accepted the answer as resolution. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
Thank you.
BY_Intel
