Ethernet Products
5610 Discussions
Lanconf NVM Image Firmware version
MJeff
Hi
Could you please explain the difference between the
Firmware Version and the NVM Version (ETRACK) fields in the NVM Image section of lanconf.
The reason I am asking is I just updated an i210 device with the latest Production image Dev_Start_I210_Copper_NOMNG_4Mb_A2_3.25_0.03.hex using eeupdate64e.efi.
After a power cycle using lanconf the NVM Version updated to 3.25 as expected but the Firmware version was not updated from 0.9 to 1.7 as I would have expected.
Is there anothe file I need to program into the i210 to update the firmware.
TIA
Hi Mjeffrey1,
Thank you for posting in Wired Communities. You may post your inquiry at our embedded support team as they can better assist you with the Lanconf inquiry
https://embedded.communities.intel.com/community/en
Hope the above information help/
Sharon T
