Ethernet Products
5782 Discussions
Link Detected: NO, Ports not UP on E810 Ethernet Controller
Zhengzhe_11030
Hi, hello
My E810 NIC is installed on the Xfusion server.
The NIC model is E810CQDA2, and the optical module model is E100GQSFP28SRX.
The model of the peer switch is Arista DCS-7280CR3-32D4, the optical module on the switch is Arista QSFP-100G-SR4, and the firmware of the switch is as follows:▁4.25.2F-207113084252F. The operating system installed on the server is CentOS7.9..
We found that the E810 NIC failed to go Up and the firmware of the NIC was 2.15. We tried to upgrade the NIC to 2.30 and 3.10, but the problem was not solved.
Could you please  suggest that what is missing or wrong?
What we have operated is as below:
1. After the optical module is removed and then inserted, some optical modules can go Up and some optical modules cannot UP
2. After the optical module is removed and inserted, the network port goes Up for about 1 minute, and the network port goes Up for 10 minutes or even two hours
3. The two ports of the E810 network adapter on the server are directly connected. The UP is normal
4. Some network adapters are normal and some network adapters are abnormal. We swap the network adapters. The normal network adapters are still normal, and the abnormal network adapters are still abnormal
5. Change the FEC mode of the NIC to AUTO, None, or BaseR. The problem cannot be solved
6. Some network adapters are always normal after optical fibers are inserted.
Zhengzhe_11030
Thank you,
Irwan_Intel
Hi Zhengzhe_11030,
Thanks for posting in the Intel Ethernet Communities. Based on what you've shared, here are a few things you can try:
1) Check out these articles for some help with port down issues: https://www.intel.com/content/www/us/en/support/articles/000087329/ethernet-products.html
2) Update your driver to version 1.11.14. You can grab it from this website: https://sourceforge.net/projects/e1000/files/ice%20stable/, or from the Intel website here: https://www.intel.com/content/www/us/en/download/19630/intel-network-adapter-driver-for-e810-series-devices-under-linux.html
3) Update your NVM firmware to the latest version (4.20)
https://www.intel.com/content/www/us/en/download/19626/non-volatile-memory-nvm-update-utility-for-intel-ethernet-network-adapters-e810-series-linux.html
4) Make sure the optical modules you're using are compatible with the Intel Ethernet Network Adapter E810-CQDA1/CQDA2.
You can check that out here: https://compatibleproducts.intel.com/ProductDetails?activeModule=Intel%C2%AE%20Ethernet&prdName=Intel%C2%AE%20Ethernet%20Network%20Adapter%20E810-CQDA1%20/%20CQDA2
If you have any other questions or worries, just let me know!
Irwan_Intel
Irwan_Intel
Hi Zhengzhe_11030,
I wanted to follow up and check if you have had the opportunity to try the suggestions I provided in the previous post.
If you have any updates or if you require further assistance, please do not hesitate to reach out.
We are committed to helping you resolve these issues effectively.
Irwan_Intel
Irwan_Intel
Hi Zhengzhe_11030,
I hope you're doing well. Unfortunately, we haven't received any response or activity on the thread for quite some time. As a result, we have decided to close the thread and it will no longer be monitored.
We understand that circumstances may have prevented you from providing further information or participating in the discussion. If you have any questions or concerns related to the topic, please feel free to create a new thread or reach out to us directly. We are here to assist you.
Irwan_Intel
