Ethernet Products
5823 Discussions
Looking for nvmupdate64 NVMUpdate version 1.38.3.7 - source code : Linux ice driver
jpdn
Hi I am a member of the Oracle Linux  kernel team
We have a version of the ice driver in our UEK6-5.4.y. kernel.
The nvmupdate64 utility included in
E810_NVMUpdatePackage_v3_20
E810_NVMUpdatePackage_v2_50_Linux.tar.gz
It Hangs when it is ran against this ice driver.
< hangs >
lspci :
 # lspci -k -v -s 17:00.0
17:00.0 Ethernet controller: Intel Corporation Ethernet Controller E810-XXV for SFP (rev 02)
Subsystem: Intel Corporation Ethernet Network Adapter E810-XXV-2 for OCP 3.0
Physical Slot: 260
Flags: bus master, fast devsel, latency 0, IRQ 16, NUMA node 0, IOMMU group 25
Memory at 21fffa000000 (64-bit, prefetchable) [size=32M]
Memory at 21fffe020000 (64-bit, prefetchable) [size=64K]
Expansion ROM at 9b800000 [disabled] [size=1M]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [70] MSI-X: Enable+ Count=1024 Masked-
Capabilities: [a0] Express Endpoint, MSI 00
Capabilities: [e0] Vital Product Data
Capabilities: [100] Advanced Error Reporting
Capabilities: [148] Alternative Routing-ID Interpretation (ARI)
Capabilities: [150] Device Serial Number b4-96-91-ff-ff-a5-80-ac
Capabilities: [160] Single Root I/O Virtualization (SR-IOV)
Capabilities: [1a0] Transaction Processing Hints
Capabilities: [1b0] Access Control Services
Capabilities: [1d0] Secondary PCI Express
Capabilities: [200] Data Link Feature <?>
Capabilities: [210] Physical Layer 16.0 GT/s <?>
Capabilities: [250] Lane Margining at the Receiver <?>
Kernel driver in use: ice
Kernel modules: ice
# modinfo ice
filename:       /lib/modules/5.4.17-2136.307.3.el8uek.x86_64/kernel/drivers/net/ethernet/intel/ice/ice.ko.xz
firmware:       intel/ice/ddp/ice.pkg
version:        0.8.2-k
license:        GPL v2
description:    Intel(R) Ethernet Connection E800 Series Linux Driver
author:         Intel Corporation, <linux.nics@intel.com>
I need to see what the utility is doing to determine what the kernel  issue may be .
Oracle is a Intel partner and has a NDA disclosure agreement.
Is there someone who can point me to a contact ?
My email is :
John   dot   p  dot   donnelly. at oracle . dot com
Thank you .
JD
