I am trying to manage a port on a XL710-DA2 NIC to use as 4 10Gbe ports without much success. This is what I tried.
1. When I run qcu, I get the following,
Intel(R) QSFP+ Configuration Utility
QCU version: v2.34.17.03
Copyright(C) 2014 - 2019 by Intel Corporation.
Software released under Intel Proprietary License.
NIC Seg:Bus Ven-Dev Mode Adapter Name
1) 000:094 8086-1583 N/A Intel(R) Ethernet Converged Network Adapter XL710
Error: Invalid image on the adapter.
2. So, I then run
./qcu64e /nic=1 /info
QSFP+ Configuration modification is not supported by this adapter.
3. Looking this up on-line tells me to update the firmware for the NIC. So I run,
[root@DSE4BC Linux_x64]# ./nvmupdate64e -a ./
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.35.23.3
Copyright (C) 2013 - 2020 Intel Corporation.
WARNING: To avoid damage to your device, do not stop the update or reboot or power off the system during this update.
Inventory in progress. Please wait [|.........]
Num Description Ver.(hex) DevId S:B Status
03) Intel(R) Ethernet Converged 7.16(7.10) 1583 00:094 Update not
Network Adapter XL710-Q2 available
Tool execution completed with the following status: Device not found.
4. I also ran the following
[root@DSE4BC Linux_x64]# ./nvmcheck64e /devices
Intel(R) NVM Integrity Verification Tool
Nvmcheck version 1.35.23.02
QV SDK version 2.35.23.02
Copyright(C) 2012 - 2020 Intel Corporation.
NIC B/D/F Ven-Dev MAC ENA Branding string
1) 025/00/00 8086-1563 E4434BDBE4BC YES Intel(R) Ethernet 10G 4P X550 rNDC
2) 025/00/01 8086-1563 E4434BDBE4BD YES Intel(R) Ethernet 10G 4P X550 rNDC
3) 026/00/00 8086-1563 E4434BDBE4BE YES Intel(R) Ethernet 10G 4P X550 rNDC
4) 026/00/01 8086-1563 E4434BDBE4BF YES Intel(R) Ethernet 10G 4P X550 rNDC
5) 094/00/00 8086-1583 F8F21E908A60 YES Intel(R) Ethernet Converged Network Ad
6) 094/00/01 8086-1583 F8F21E908A61 YES Intel(R) Ethernet Converged Network Ad
[root@DSE4BC Linux_x64]# ./nvmcheck64e /nic=5 /verify
NVM module: PCIe Analog.
NVM Integrity verification PASSED.
NVM module: PHY Analog.
NVM module: Option ROM.
NVM module: EMP image.
So, I am wondering what my next step is.
Greg
Hello gpage,
Thank you for posting in Intel Ethernet Communities and we sincerely apologize for the delay on our response. We are now done with the system upgrade and we will be glad to continue assisting you.
We noticed that you have opened another ticket with your local support group and the ticket has been closed already. With this, please be informed that we will also proceed closing this request. If you need any additional information, please submit a new question as this thread will no longer being monitored.
May you have an amazing day ahead!
Crisselle C
Intel® Customer Support
