Ethernet Products
Intel® Ethernet products and technologies
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
3937 Discussions
Maximum 200 MB/Sec with X520-T2 Cards... ???
Community Manager
Hi, we have installed in our company 6 server wiht the X520-T2 (SPF+) cards and DELL 10Gbit switches and EqualLogic SANs... all nice, ut i got only a average transfer rate, measured with iperf, of 200 MB/sec...??
Ok, i have created another test scenario^with one dell and one ibm server (16 cores, 32gb ram) and connected the 2 server via a SPF+ (cable from dell) direct without any switch, same result ~200 MB/Sec.
We checked the packets with wireshark and all are jumbo frames without truncation and wihtout defragmentation.
the os for the test was windows 2008 r2 and windows 2008 64bit with a fresh installation and the intel driver from the homepage.
all offload settings in the drivers was disabled.
anyone a idea why i'm get this poor transfer rates???
i have the same speed with vmware, xenserver and windows 7 on 5 different machines...
whats the trick' is this a cable problem?
thank you for any tips for this boring problem.
Volkan
Community Manager
No one a idea for me
Volkan
vt5
some tips:
-ensure pci-e slot is x8 configured, update bios if needed
-tune the tcp window size
you can also check out this site - http://www.intel.com/support/network/sb/CS-025829.htm http://www.intel.com/support/network/sb/CS-025829.htm
Community Manager
Thank you sage99, one of the server are a dell R410 and has a speed of x16 > http://www.dell.com/us/en/enterprise/servers/server-poweredge-r410/pd.aspx?refid=server-poweredge-r4... http://www.dell.com/us/en/enterprise/servers/server-poweredge-r410/pd.aspx?refid=server-poweredge-r4...
I have not found a special settings for the PCIe bus...?
The document about optimizing the nics i have tryed before without any success, has the X520 cards any hidden bios/firmware settings?
i have not seen on boot for a key to enter, to enter the menu like other hba/scsi/nic card.
Volkan
