Ethernet Products
5821 Discussions
Maximum number of VLANs I350 Gigabit Network Connection (rev 01)
Buyiyo
Good Morning,
What is the maximum number of VLANs that I can pass through an ethernet port for the I350 Gigabit Network Connection adapter (rev 01)?
I am using this nic with Proxmox, where I will use 2 ports in LACP mode.
Greetings.
Caguicla_Intel
Hello Buyiyo,
Please share the following information that would help in checking you request.
1. PBA of the adapter. You may refer to the link below on where to find the PBA number. It consist of 6-3 digit number located at the last part of the serial number. This would help us identify if you are using an Original Equipment Manufacturer(OEM) or retail version of Intel Ethernet Adapter.
Identify Your Intel® Network Adapter Model Using PBA Number
https://www.intel.com/content/www/us/en/support/articles/000007022/network-and-i-o/ethernet-products.html
2. Is this initial integration or your setup has been working already?
Awaiting to hear from you.
Should there be no reply, we will follow up after 3 business days.
Crisselle C.
Intel® Customer Support
Buyiyo
Good afternoon,
Currently it is impossible for me to obtain the PBA as they are in use in a remote environment.
Yes, I can get the MAC of each interface on the card, in case I can help.
Comment that it is an original piece of INtel supplied for compatibility with supermicro server.
Greetings.
Caguicla_Intel
Hello Buyiyo,
No problem at all, appreciate your swift reply.
Please allow us to further check your query. We will get back to you in case additional information or needed and rest assured that we will give you an update as soon as possible but no later than 2-3 business days.
Hoping for your kind patience.
Crisselle C.
Buyiyo
Any news regarding this matter?
I am waiting to receive news,
Greetings.
Caguicla_Intel
Hello Buyiyo,
Apologies for the delay on this matter.
Based on Intel® Advanced Network Services VLANs link below, Intel® software supports a maximum of 64 VLANs per network port or team.
Refer to this link for Intel® Advanced Network Services VLANs
https://www.intel.com/content/www/us/en/support/articles/000005677/network-and-i-o/ethernet-products.html
We would also like to share with you the list of Supported Operating Systems for Retail Intel® Ethernet Adapters. You may visit this link to see the supported Operating system for I350 adapters.
https://www.intel.com/content/www/us/en/support/articles/000025890/network-and-io/ethernet-products.html
We will also further check your exact inquiry below with our engineers and get back to you within 2-3 business days.
Feel free to let us know if you have additional questions and clarifications.
Crisselle C.
Caguicla_Intel
Hello Buyiyo,
Apologies for the delay on this request.
While we are checking this with our higher level support, can you confirm that you are only using Promox? If no, are there any other OSes installed in the server? Please share the Operating System used.
We hope to hear from you soon.
Should there be no response from you, I’ll make sure to reach out after 3 business days.
Crisselle C.
Buyiyo
Yes, I can confirm that we only use proxmox as our operating system.
Through this we have LACP layer 2+3 configured.
If you need any extra details please don't hesitate to ask,
I look forward to hearing from you,
Regards.
Caguicla_Intel
Dear Buyiyo,
Thank you for the swift response.
Please allow us to re-escalate this request to our higher level. We will get back to you as soon as possible but no later than 3 business days.
Crisselle C.
Caguicla_Intel
Dear Buyiyo,
We sincerely apologize for the delay on this matter.
Unfortunately, what we can only provide is the hardware level information. You may check the datasheet (link below) for the I350. However, since Proxmox is an open source OS, we highly recommend contacting Promox drivers support or log in the Promox Forum for further assistance. We believe that someone from Promox forum will be able to assist you about the maximum VLAN inquiry.
https://forum.proxmox.com/
Intel® Ethernet Controller I350: Datasheet
http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/ethernet-controller-i350-datasheet.pdf
We have also shared this on our previous post and unfortunately, Proxmox is not listed as validated OS for I350. You may visit this link to see the supported Operating system for I350 adapters.
Awaiting to your reply.
Crisselle C.
Buyiyo
Good morning,
I will make the query in the Proxmox forum, as soon as I get a reply I will update the status of this post.
Regards.
Caguicla_Intel
Dear Buyiyo,
Thank you for the reply.
While you are waiting for feedback from Proxmox team, can you please confirm if you wish to keep this request open? If no, kindly advise if you're okay to proceed with request closure.
Feel free to let us know if you have additional assistance needed on this matter and we will be glad to check on it.
Should there be no response, I’ll make sure to reach out after 3 business days.
Crisselle C.
Caguicla_Intel
Hello Buyiyo,
Good day!
This is just a follow up to check if you have additional questions and clarifications on this query. If you do, please let us know and we will be glad to check on it.
Crisselle C.
Caguicla_Intel
Hello Buyiyo,
I hope you're doing good!
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
Thank you for choosing Intel and stay safe!
Crisselle C.
Buyiyo
Good morning,
Sorry for the delay, here is the reply from proxmox.
* the pve-kernel ships the in-tree drivers for the intel NICs - the output of `modinfo igb` will tell you (and Intel support) the concrete version
* a quick look in the kernel source (for the current 5.11 kernel) has an occurence of the define:
#define E1000_VLAN_FILTER_TBL_SIZE 128 /* VLAN Filter Table (4096 bits) */
which is also used in the igb driver
- so my guess would be that the limit is 128
* IIRC you should be able to configure more vlans, if you disable vlan-offloading via `ethtool`
Regards.
