Ethernet Products
5611 Discussions
Mechanical dimension for E10G42BFSR
GChon
May I know the mechanical dimension of this ethernet card (E10G42BFSR)?
The datasheet which we have download from Intel website does not have the overall height profile that we need.
The dimension is based on the L and W. It doesn't have the overall height as we need to know if the heatsink will protrude beyond the bracket.
We are concern that the height of the heatsink on the Intel Server adapter card might block our chassis as we are installing it on a 1U system.
Please help to advise the mechanical dimension of the card. Thanks.
Chong
SYeo3
Valued Contributor I
Hi Chong,
Thank you for contacting Intel. I'll check on this.
Sincerely,
Sandy
SYeo3
Hi Chong,
The Intel X520 Series Server Adapter is complies the with standards of 1U systems. Please advise if you will require the dimension.
Sincerely,
Sandy
GChon
Hi Sandy,
Please help to advise the dimension if possible. Thanks.
Sincerely,
Chong
SYeo3
Hi Chong,
Thanks for your reply. I'll follow-up on this.
Sincerely,
Sandy
SYeo3
Hi Chong,
I'm so sorry for the delay.
The height of the heat sink is .560 inch, it doesn't go beyond the adapter's bracket.
Hope I was able to address your concerns.
Sincerely,
Sandy
