Ethernet Products
5821 Discussions
MonitorMode on x710 and i226 NIC
schneids
In my system, I have Intel i226-LM, i226-V 2.5G ethernet interfaces as well as dual 10G SFP+ X710 interfaces.  I cannot get these to pass the VLAN or mac control (like Ethernet PAUSE frames) up to the sniffer.  They are all running latest intel driver versions:
i226-LM : 2.1.4.3
i226-V: 2.1.4.3
X710: 1.19.164.0
From what I can see in this doc, the driver versions do not refer the drivers for the x710 SFP+ NIC nor the i226L 2.5G ethernet adapters.
My Sniffer Isn't Seeing VLAN, 802.1q, or QoS Tagged Frames (intel.com)
In this doc, it says for the 700 series, the Driver is i40ea and i40eb.  For the 2.5G adapter, it says driver is e2f.  These are not referenced in the wireshark sniffer note above.
Intel® Ethernet Controller Products Release Notes
Does anyone know what to use in order to get Wireshark to show VLAN tags, and even 802.3x PAUSE frames for these network devices?  I've tried MonitorMode and MonitorModeEnabled both set to 1 for these and it is still not working.  At some point it would seem this kind of setting should be put into the driver config that is exposed to the user like setting like many other low level things are, such as checksum offload, flow control, EEE, VLAN ID, etc.
Sazirah
Hi schneids,
Thank you for posting in Intel Community Forum.
Regarding the issue reported, kindly give us some time while we are checking on this. We will revert back to you with an update soon.
Sazzy_Intel
Sazirah
Hi schneids,
Good day.
Related to your issue above, please follow below setting:
Settings in Wireshark --Ensure Promiscuous Mode is enabled.
Set your NIC to promiscuous mode to capture all packet
Also, to help us to investigate further, kindly help to generate the SSU logs and share with us, you may refer link below for the guidance:
https://www.intel.com/content/www/us/en/support/articles/000008563/ethernet-products.html
Sazzy_Intel
Sazirah
Hi schneids,
Good day.
This is related to your enquiries above, I would like to check if the issue has resolved?
If you have any questions or clarifications, please let me know.
Sazzy_Intel
Sazirah
Hi schneids,
Good day
This is regarding your enquiries above. Since we have not seen an update, if you need any additional information, please submit a new question as this thread will no longer be monitored.
Sazzy_Intel
