Ethernet Products
5611 Discussions
My Internet speed is capped at 100/100 mbps on i219 v
ZENN
I think I have a problem with my driver or software already check my lan cable(cat6) my router is also cappable of 1 gbps aswell. Can someone help? mainboard is z390elite Down there is my ssu report
ClariceStarling
Valued Contributor II
Did you contact your ISP ... seems like they might help?
Mike_Intel
Hello ZENN,
For us to further check and investigate the issue, please provide the following details.
  1. Are you using an onboard Network card?
  2. Is it working fine before?
  3. Can you share a screenshot of the issue?
  4. Can you provide the link of your latest driver?
  5. Can you share some troubleshooting steps that you tried so far?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Mike_Intel
Hello ZENN,
I hope this message finds you well. I am just sending a follow up on the following details for us to check your inquiry.
Michael L.
ZENN
Sorry for a 3 week late answer I almost forgot that I post this
1.Yes its a onboard network card
2.I never tried 1gbps speed before but but the last time its working fine for a speed at 60mbps
3.Yes, here you can see its capped at 100/100mbps
4. I didnt update my driver its a same driver as the day I have my pc since 2019
5.I,ve tried some new lan cable and find a driver but didnt install anything yet cus i know i will mess this up
Mike_Intel
Hello ZENN,
Thank you for the prompt reply. Let me clarify some information from your reply.
  1. What is your OS?
  2. Have you tried checking with the board manufacturer of they have the latest driver for your onboard network card?
  3. I understand that you are having second thoughts in installing the latest driver, however those drivers contain the fixes for the issues.
  4. You may also follow the step below on how to clean install the driver.
https://www.intel.com/content/www/us/en/support/articles/000058304/ethernet-products.html?productId=49188&localeCode=us_en
Michael L.
ZENN
1.Im currently running on a window10
2.No, Ive not yet contact them for a help but I'll try that out
4.Not yet but how can I find the right driver for my computer?
thanks for your help
Mike_Intel
Hello ZENN,
I hope this message finds you well. I am just checking if you tried our last recommendations to update the driver and perform clear driver installation.
Michael L.
Mike_Intel
Hello ZENN,
Thank you so much for the update. By the way, what is the brand and model of your board or system?
Regarding the driver, here is our latest driver for your I219-V, just follow the clean driver installation procedure in installing the latest driver.
Latest driver:
https://downloadcenter.intel.com/download/25016/Intel-Network-Adapter-Driver-for-Windows-10
Clean driver installation steps:
Thank you.
Michael L.
Mike_Intel
Hello ZENN,
I hope you enjoyed your weekend. I am just making a follow up on the brand and model of your system.
Thank you.
Michael L.
AlHill
Make sure you check ALL cables and switches.  They must be cat 5e or greater.  If you are splittig a cable, do not do that.
[Windows 11 is the new Vista]
Mike_Intel
Hello ZENN,
I am just sending another follow up on the information that I requested.
If you need further assistance, please post a new question.
Thank you and stay safe.
Michael L.
