Ethernet Products
5821 Discussions
NIC low latency driver, write own c++ driver or ?
schri19
Has anyone looked into low-latency NIC drivers? We can't seem to get lower than 0.5ms to reply to a socket message on Windows Server 2008, the whole stack is setup to buffer everything for high bandwidth, wondering if I should attempt to write a new driver or if there is any other solution out there.
Caguicla_Intel
Hello schri19, Thank you for posting in Intel Ethernet Communities. Please provide the following details for us to check on your query. 1.) Model of the NIC card 2.) Driver version installed 3.) Website where the driver was downloaded Looking forward to your response. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
Caguicla_Intel
Hello schri19, Please provide the details that we require for us to check on your query. Looking forward to your response. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
Caguicla_Intel
Hello schri19, We'd like to follow up the requested details for us to check on your query. Looking forward to your response. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
