Ethernet Products
5534 Discussions
NIC-rich but CPU-poor?
Recently we got a few new servers. All have identical configuration. Each has dual E5-2620v3 2.4Ghz CPUs, 128GiB RAM (8 x 16GiB DDR4 DIMMs), 1 dual-40G XL710, and two dual 10G SPF+ mezz cards (i.e. 4 x 10G SPF+ ports). All of them run CentOS 7.1 x86_64. These XL710s are connected to the 40G ports of http://www.quantaqct.com/Product/Networking/Ethernet-Switches/T3000-Series/QuantaMesh-T3048-LY8-p43c77c75c158c205 QCT LY8 switches using genuine Intel QSFP+ DACs. All 10G SPF+ ports are connected to Arista 7280SE-68 switches, but using third party DACs. All systems have been so far minimally tuned:
  • In each's BIOS, the pre-defined "High Performance" profile is selected, furthermore, Intel I/OAT is enabled, VT-d is disabled (We don't need them to run virtual machines, they are for HPC applications).
  • In each's CentOS, the tuned-adm active is set to network-throughput.
After the servers have been setup, we have been using iperf3 to run long-running tests among such servers. So far, we have observed consistent packet drops on the receiving side. An example:
[root@sc2u1n0 ~]# netstat -i
Kernel Interface table
Iface MTU RX-OK RX-ERR RX-DRP RX-OVR TX-OK TX-ERR TX-DRP TX-OVR Flg
ens10f0 9000 236406987 0 0 0 247785514 0 0 0 BMRU
ens1f0 9000 363116387 0 2391 0 2370529766 0 0 0 BMRU
ens1f1 9000 382484140 0 2248 0 2098335636 0 0 0 BMRU
ens20f0 9000 565532361 0 2258 0 1472188440 0 0 0 BMRU
ens20f1 9000 519587804 0 4225 0 5471601950 0 0 0 BMRU
lo 65536 19058603 0 0 0 19058603 0 0 0 LRU
We have also observed iperf3 retries at the beginning of a test session and often, during a session (not as often however). Two examples:
40G pairs:
$ iperf3 -c 192.168.11.100 -i 1 -t 10
Connecting to host 192.168.11.100, port 5201
[ 4] local 192.168.11.103 port 59351 connected to 192.168.11.100 port 5201
[ ID] Interval Transfer Bandwidth Retr Cwnd
[ 4] 0.00-1.00 sec 2.77 GBytes 23.8 Gbits/sec 54 655 KBytes
[ 4] 1.00-2.00 sec 4.26 GBytes 36.6 Gbits/sec 0 1.52 MBytes
[ 4] 2.00-3.00 sec 4.61 GBytes 39.6 Gbits/sec 0 2.12 MBytes
[ 4] 3.00-4.00 sec 4.53 GBytes 38.9 Gbits/sec 0 2.57 MBytes
[ 4] 4.00-5.00 sec 4.00 GBytes 34.4 Gbits/sec 7 1.42 MBytes
[ 4] 5.00-6.00 sec 4.61 GBytes 39.6 Gbits/sec 0 2.01 MBytes
[ 4] 6.00-7.00 sec 4.61 GBytes 39.6 Gbits/sec 0 2.47 MBytes
[ 4] 7.00-8.00 sec 4.61 GBytes 39.6 Gbits/sec 0 2.88 MBytes
[ 4] 8.00-9.00 sec 4.61 GBytes 39.6 Gbits/sec 0 3.21 MBytes
[ 4] 9.00-10.00 sec 4.61 GBytes 39.6 Gbits/sec 0 3.52 MBytes
[ 4] 0.00-10.00 sec 43.2 GBytes 37.1 Gbits/sec 61 sender
[ 4] 0.00-10.00 sec 43.2 GBytes 37.1 Gbits/sec receiver
82599 powered 10G pairs:
$ iperf3 -c 192.168.15.100 -i 1 -t 10
Connecting to host 192.168.15.100, port 5201
[ 4] local 192.168.16.101 port 53464 connected to 192.168.15.100 port 5201
<span style="font-family: 'courier ne...
SYeo3
Valued Contributor I
Hi Zack,
Thank you for contacting Intel. I'll check on this and will update you accordingly.
Sincerely,
Sandy
Hi Sandy
Any updates?
Thanks!
-- Zack
SYeo3
Hi Zack,
We are checking this with your system setup. Thank you for your patience and understanding.
Sincerely,
Sandy
SYeo3
Hi Zack,
Good day.
We would like to request for your adapter details. Please run ethtool -I and post the output here.
Please try to set the port to 10Gbps and see the test results.
We look forward to your reply.
Sincerely,
Sandy
Hi Sandy
Please see below. Should you need any info, please just ask. All eight servers use the same configuration. Thus, even the following was obtained on just one node. It's representative.
ens10f0 is the 40G port (one of the two of XL710)
The rest are 10G port (82599)
-- Zack
[root@sc2u0n0 ~]# for if in ens10f0 ens20f{0..1} ens1f{0..1}
> do
> ethtool -i $if
> echo "ethtool -i for $if done..."
> done
driver: i40e
version: 1.3.38
firmware-version: 4.24 0x800013fc 0.0.0
bus-info: 0000:02:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
ethtool -i for ens10f0 done...
driver: ixgbe
version: 4.1.2
firmware-version: 0x800004e0, 1.808.0
bus-info: 0000:01:00.0
supports-test: yes
supports-priv-flags: no
ethtool -i for ens20f0 done...
driver: ixgbe
version: 4.1.2
bus-info: 0000:01:00.1
supports-test: yes
ethtool -i for ens20f1 done...
driver: ixgbe
version: 4.1.2
firmware-version: 0x80000646, 1.446.0
bus-info: 0000:07:00.0
supports-test: yes
ethtool -i for ens1f0 done...
driver: ixgbe
version: 4.1.2
bus-info: 0000:07:00.1
supports-test: yes
ethtool -i for ens1f1 done...
[root@sc2u0n0 ~]#
Hi Sandy
Quick follow-up:
I have a script that enables me to check the speed of all interfaces. We have 40 of them The script calls ethtool iface remotely over ssh and extract the Speed line. Since all servers were online, all interfaces have been running at their rated speed. We don't have a need to manually force anyone of to run at rated speed thus far.
$ ./iface_speed.sh |grep Speed
Speed: 40000Mb/s
Speed: 40000Mb/s
Speed: 40000Mb/s
Speed: 40000Mb/s
Speed: 40000Mb/s
Speed: 40000Mb/s
Speed: 40000Mb/s
Speed: 40000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
Speed: 10000Mb/s
$ ./iface_speed.sh |grep Speed|wc -l
40
-- Zack
SYeo3
Hi Zack,
Sorry for my late reply. Thanks for coming back with the details. I am checking on this.
Sincerely,
Sandy
SYeo3
Hi Zack,
Please refer to website below for some suggested settings to improve system's performance.
http://www.intel.com/support/network/sb/CS-025829.htm Network Connectivity — Tuning Intel® Ethernet Adapter Throughput Performance
- scroll down to Related Topics, then click on "Performance Tuning for 10 Gigabit Ethernet adapters in Linux*"
Hope this help improve the your systems' overall performance.
Sincerely,
Sandy
