Ethernet Products
5614 Discussions
New Gigabyte Z790 board keeps disconnecting from Internet. I225-V (3) controller problem
jucca
Hi guys, recently bought Gigabyte Z790 AERO G mobo with integrated I225-V (3) controller, and since then, i have random disconnects on daily basis. Sometimes need to disable/enable adapter to get it working again, sometimes physical reconnect, and even need to reboot PC.
Saw in past people had problems with very same controller, on Z490 boards, but can't find anywhere firmware update tool and never firmware for this particular ethernet card.
Have all the updates, as well as BIOS.
My event viewer shows error 37 and 32
https://ibb.co/h9Q4BPs
https://ibb.co/HPBqqcf
Mike_Intel
Hello jucca,
For us to further check the issue, please provide the following details.
  1. What is your OS?
  2. Can you share the link of the network driver that you are using?
  3. Is there a particular program that is causing the issue?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel® Customer Support
Mike_Intel
Hello jucca,
I hope you're having a wonderful day. I am just sending a soft follow up on the information that we requested for us to further assist you. We will wait for your reply.
Michael L.
jucca
Hi Mike
I'm using Windows 11 22H2
Drivers were first downloaded from Gigabyte  page:
https://www.gigabyte.com/Motherboard/Z790-AERO-G-rev-10/support#support-dl-driver-lan
Didn't worked, then I downloaded driver package from your page:
https://www.intel.com/content/www/us/en/download/727998/intel-network-adapter-driver-for-microsoft-windows-11.html
Mostly crashes when playing online games, like Shatterline, COD MW2, iRacing.
Mike_Intel
Hello jucca,
Appreciate the quick reply. We have a documented recommendation for the issue. Please check the link below:
https://www.intel.com/content/www/us/en/support/articles/000057261/ethernet-products/gigabit-ethernet-controllers-up-to-2-5gbe.html
To update the NVM firmware, you need to contact the OEM manufacturer which is Gigabyte. Intel's NVM update file will not work and may damage OEM cards and vice versa. Onboard/Embedded network cards are considered as an OEM unit so it is best to coordinate the issue further with Gigabyte.
Michael L.
jucca
Thanks for replay.
As I stated in first post, there's no tool to update FW in Gigabyte page
However, found one utility, wich saysbI have 1.68FW wich I believe is the latest one
Mike_Intel
Hello jucca,
Thank you for quick reply. Different manufacturers may have different procedure in updating the NVM firmware and they should have their own NVM file as well. It is best to contact Gigabyte and ask them for the update procedure.
Michael L.
jucca
Thanks for answer.
Yes, i did contacted Gigabyte, and they want to RMA my board. But what's the point if the failure would be the same.
I have already latest FW on my Intel NIC
Mike_Intel
Hello jucca,
Thank you for the update and we are glad that Gigabyte is now helping you, If you will have the same issue, kindly coordinate with Gigabyte since it is an OEM unit, they may have altered the network card so they know how to diagnose it.
Since the board is now for RMA, we will close this case now.
Thank you and stay safe.
Michael L.
