Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Re:New version of Windows 10 2004, the same proble...
Hi fredless,
Thank you for the update.
For the other users, version 25.1.1 is already available. Please install it on your systems and see if it resolves your issue.
Looking forward to your replies, should we not hear from you, we will reach out after 3 business days.
Alfred S
Intel Customer Support
Highlighted
Hi Community Members,
We are following up if version 25.1.1 address the issues that you raised on this forum.
Looking forward to your replies, should we not hear from you, our system may automatically close the ticket..
Alfred S
Highlighted
Re: Re:New version of Windows 10 2004, the same proble...
Yes and no.
Yes, ANS works at least as far as VLANs go; I have not tested teaming.
No, the drivers do not work correctly in that they break the PowerShell *-NetAdapter cmdlets again, a bug that existed in the 23/24 timeframe and was fixed in 25.0. The symptoms with 25.1.1 are the same as back then.
Highlighted
Hi CUllr,
Thank you for your feedback.
Kindly give us more information about the bug that you encountered. We would appreciate it if you could share screenshots of it.
Looking forward to your reply. Should we not hear from you, we will follow up after three business days.
Alfred S
Intel® Customer Support
Highlighted
Re: New version of Windows 10 2004, the same problem of vlan and nic teaming
Our organisation has about 50 PC's that are set up with NIC teaming.
Every feature update the teaming settings are wiped and it has to manually reconfigured on every machine.
Surely Microsoft and Intel, given their partnerships, have or can find a solution to this issue?
I have installed 25.1.1 on a Windows 10 1709 device and upgraded to Windows 10 1909 and it has still dropped all the settings.
We are using the Intel(R) Ethernet I210-T1 cards.
Could anyone advise a solution for this issue?
Cheers
Highlighted
Have installed 25.1.1 right after it was available. It broke all network connectivity and despite many efforts was not able to get it up. Had to reinstall an earlier version to get the box running again because with networking such a box is a lame duck. IMO Intel did a very bad job with this version and at the same time updated their forum so it was not possible to warn other people. Regards. Marcel
Highlighted
Hi MarkT and Mschn22,
Thank you for the feedback and reporting the issue that you encountered with the recent update. We will take note of the inconveniences that you have experienced.
Alfred S
Highlighted
Hi CUllr,
We are just following up.
It looks like you need more time to provide the information that we asked.
We will follow up again after 3 business days. Should we not hear from you, we will start checking the other issues posted by other community members on this thread, until the time that you can reply to us.
Alfred S
Highlighted
Hi Alfred S., if we can help somehow pls let us know. In my case, the Intel driver found no adapters and when checking in Device Manager - Network Adapter, instead of "Device working properly", it displayed something like that the device is still installing (same on both NIC's) but it was not finished after waiting 1 day. Could even no longer install the old 25 version with the same effects, it was necessary to fully reinstall Win 10 from backup. Currently this works again with only 1 NIC. Kind regards, Marcel
Highlighted
for an illustration of the issue, please see this older post: https://community.intel.com/t5/Ethernet-Products/23-5-Vlans-break-Windows-Powershell-Get-NetAdapter/...
The screenshot is from 24.something, but the PowerShell error is exactly the same in the current version.
The driver versions in the windows I arranged around the PowerShell window are different in 25.1.1, of course. If at all possible, I would appreciate not being told that I'm using an old driver and to try the current one. I have seen the error with 25.1.1, have since reverted to an earlier driver version in which PowerShell works (though ANS doesn't), and I am not going to break this system by installing the known-bad 25.1.1 again. Thank you.
Highlighted
1 View
Hi CUllr,
Thank you for your detailed response.
We will start further checking on your issue together with the issues recently raised by two other community members on this thread.
We will get back to you no later than 5 business days from now.
Alfred S
