Ethernet Products
5743 Discussions
Not able to install Intel Killer™ Performance Suite
StéphaneH
I have a Dell Alienware Aurora 13 with Windows 11.
After running the Intel Driver & Support Assistant, I see that the driver "Killer E3100 G 2.5 Gigabit Ethernet Controller" needs to be replaced by the Intel Killer Performance Suite.
But each time I try to install it, I get the error 2732 (Error 2732 Directory Manager not Initialized).
The Wifi driver is Wi-Fi 6E AX210 160MHz and I think this is up-to-date.
Is there a solution for this problem ?
Thanks in advance
Stéphane
JedG_Intel
Hello StéphaneH
I understand that you are experiencing issues with installing the Intel Killer™ Performance Suite. Since you have a Dell Alienware laptop, which is considered an OEM device, we recommend using drivers provided by the OEM. Your computer manufacturer may have altered the features, incorporated customizations, or made other changes.
Please try to follow the steps below and let me know if it helps.
  • Uninstall Killer™ Control Center if it was been installed before installed Killer™ Performance Suite.
  • Download the latest version of the Intel® Killer™ Performance Suite.
  • Turn off Wi-Fi and remove the network cable.
  • Open Device Manager, right click Killer® Wi-Fi 6 AX1650w, click Uninstall Device.
  • Right click Killer® E3100X, click Uninstall Device.
  • Install Intel Killer Performance Suite.
For reference: Encountered Error: "Error 2732 Directory Manager not Initialized" when Installing Intel® Killer™ Performance Suite
I'm looking forward to your response.
Jed G.
CanOrhan
Hi there,
I have the same problem. I applied what you said but I can't install. I get the same error code. My laptop is msi stealth series killer wifi 7 be1750x
Best Regards
Can
JedG_Intel
Hi StéphaneH,
I wanted to check if you had the chance to try the recommendations I posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Hello @CanOrhan
I understand that you're also having the same issue. To avoid confusion and for proper support, please create a different thread.
Jed G.
CanOrhan
Hi Jed
First of all, I'm sorry about the message, the e-mails went to the junk box. I did what you said again, but the problem persists.
1. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently? - Yes I uninstalled and reinstalled
2.Is this a new computer? - yes this is new laptop
3. Were you able to install Intel Killer Performance Suite previously? - no
4. Please generate SSU report. - I tried but it does not submit
5. Please attach the screenshot of the exact error message. - Screenshots are attached.
JedG_Intel
Hi StéphaneH,
I sent you an email to continue the support. Please check your inbox at your earliest convenience.
Jed G.
StéphaneH
My problem (PC freezing regularly for 30-60 sec.) seems to be solved (hopefully).
I just performed a clean boot and disabled  all the apps that were not related to Microsoft services nor to the antivirus program.
See https://www.makeuseof.com/clean-boot-windows-11/?_x_tr_sl=auto&_x_tr_tl=fr&_x_tr_hl=en-US
I haven't experienced a freeze since then (more than a week).
But I have not been able to install the Intel Killer Performance Suite, even after having followed the steps you advized.
Stéphane Herens
JedG_Intel
Hi StéphaneH,
I'm glad to hear that after a clean boot, the freezing issue was resolved. Since you're still having issues with installing Intel Killer Performance Suite, I would like to investigate further. Please share the information below.
I hope to hear from you soon.
Jed G.
JedG_Intel
Hello StéphaneH,
I'm just following up with regards to the questions that I posted. Please share the information as soon as possible so we can investigate further.
Jed G.
VonM_Intel
Hello, StéphaneH.
I have not heard back from you, I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
