Ethernet Products
4531 Discussions
Not getting traffic in promisc sriov
Hi
1. Is this possible to do what i am trying to do?
a. If yes, what is my problem
b. sr-iov is only to use with vlan?
I am using Intel Corporation 82599ES 10-Gigabit SFI/SFP+
ethtool -i eth6
driver: ixgbe
version: 3.19.1-k
firmware-version: 0x80000597
bus-info: 0000:15:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: no
I am trying to do passthrough to guest using sriov and libvirt
I did assignment from a pool of SRIOV VFs in a libvirt definition as following
passthrough-eth6
I launch the vm, there is a vm with virt-install …. --network network=passthrough-eth6
I inject traffic with a generator so I defined it in promisc mode without an ip address.(ifconfig eth6 promisc up)
In my physical device eth6 i can see RX increasing. But in the guest side nothing arrive in the RX? Why?
I don't know in which log to look at to understand the problem
I defined the network-script/eth1 file in the guest is defined as static (not dhcp) as the interface it is connected to in host have no ip.
I have a another interface on the host connected via ovs and libvirt and it is working fine – you can see it in log as vnet0(thanks to this mailing-list help).
In the guest part I attached the log but I think interesting part is
Jan 27 17:03:21 localhost kernel: ixgbevf 0000:00:04.0: NIC Link is Up, 10 Gbps
Here is the log from the host side, I can't see an error. /var/log/message
Jan 27 12:02:29 1235 avahi-daemon[2598]: Withdrawing address record for fe80::fc54:ff:fe92:7352 on vnet0.
Jan 27 12:02:29 1235 kernel: device vnet0 left promiscuous mode
Jan 27 12:02:30 1235 kernel: ixgbe 0000:15:00.0: setting MAC a2:fc:a8:89:2a:8f on VF 0
Jan 27 12:02:30 1235 ovs-vsctl: 00001|vsctl|INFO|Called as ovs-vsctl --timeout=5 -- --if-exists del-port vnet0
Jan 27 12:02:30 1235 ovs-vswitchd: 00180|bridge|ERR|bridge virbr0: mirror mirror-1-to-3 does not specify output; ignoring
Jan 27 12:02:31 1235 ntpd[2905]: Deleting interface # 28 vnet0, fe80::fc54:ff:fe92:7352# 123, interface stats: received=0, sent=0, dropped=0, active_time=981 secs
Jan 27 12:02:31 1235 ntpd[2905]: peers refreshed
Jan 27 12:02:43 1235 kernel: ixgbe 0000:15:00.0: Reload the VF driver to make this change effective.
Jan 27 12:02:43 1235 kernel: kvm: 7957: cpu0 unhandled rdmsr: 0x345
Jan 27 12:02:43 1235 kernel: kvm: 7957: cpu0 unhandled wrmsr: 0x680 data 0
Jan 27 12:02:51 1235 ovs-vsctl: 00001|vsctl|INFO|Called as ovs-vsctl --timeout=5 -- --may-exist add-port br3 vnet0 -- set Interface vnet0 "external-ids:attached-mac=\"52:54:00:43:BF:8C\"" -- set Interface vnet0 "external-ids:iface-id=\"309ed431-417f-2843-89b8-179a066aa595\"" -- set Interface vnet0 "external-ids:vm-id=\"870e3b65-953b-01ee-84a3-c2d05300c2d9\"" -- set Interface vnet0 external-ids:iface-status=active
Jan 27 12:02:51 1235 ovs-vswitchd: 00183|bridge|ERR|bridge virbr0: mirror mirror-1-to-3 does not specify output; ignoring
Jan 27 12:02:51 1235 kernel: device vnet0 entered promiscuous mode
Jan 27 12:02:51 1235 kernel: ixgbe 0000:15:00.0: setting MAC 52:54:00:d9:f1:bd on VF 0
Jan 27 12:02:51 1235 kernel: ixgbe 0000:15:00.0: Reload the VF driver to make this change effective.
Jan 27 12:02:51 1235 kernel: pci-stub 0000:15:10.0: enabling device (0000 -> 0002)
Jan 27 12:02:52 1235 avahi-daemon[2598]: Registering new address record for fe80::fc54:ff:fe43:bf8c on vnet0.*
Jan 27 12:02:54 1235 ntpd[2905]: Listen normally on 29 vnet0 fe80::fc54:ff:fe43:bf8c UDP 123
Jan 27 12:02:54 1235 ntpd[2905]: peers refreshed
Jan 27 12:03:17 1235 kernel: __ratelimit: 23 callbacks suppressed
Jan 27 12:03:17 1235 kernel: kvm: 8006: cpu0 disabled perfctr wrmsr: 0xc1 data 0xabcd
Jan 27 12:03:20 1235 kernel: ixgbe 0000:15:00.0: eth6: VF Reset msg received from vf 0
And this is the /var/log/libvirt/qemu/probe8.log from the host
2015-01-27 17:02:51.762+0000: starting up
LC_ALL=C PATH=/sbin:/usr/sbin:/bin:/usr/bin QEMU_AUDIO_DRV=none /usr/libexec/qemu-kvm -name probe8 -S -M rhel6.6.0 -enable-kvm -m 4096 -realtime mlock=off -smp 4,sockets=4,cores=1,threads=1 -uuid 870e3b65-953b-01ee-84a3-c2d05300c2d9 -nodefconfig -nodefaults -chardev socket,id=charmonitor,path=/var/lib/libvirt/qemu/probe8.monitor,server,nowait -mon chardev=charmonitor,id=monitor,mode=control -rtc base=utc -no-shutdown -device ich9-usb-ehci1,id=usb,bus=pci.0,addr=0x5.0x7 -device ich9-usb-uhci1,masterbus=usb.0,firstport=0,bus=pci.0,multifunction=on,addr=0x5 -device ich9-usb-uhci2,masterbus=usb.0,firstport=2,bus=pci.0,addr=0x5.0x1 -device ich9-usb-uhci3,masterbus=usb.0,firstport=4,bus=pci.0,addr=0x5.0x2 -drive file=/data/KVM/comp_VNF_MaveriQ_Probe2-cloud8.qcow2,if=none,id=drive-ide0-0-0,format=qcow2,cache=none -device ide-drive,bus=ide.0,unit=0,drive=drive-ide0-0-0,id=ide0-0-0,bootindex=1 -drive file=/var/lib/libvirt/images/configuration8.iso,if=none,id=drive-virtio-disk0,format=raw,cache=none -device virtio-blk-pci,scsi=off,bus=pci.0,addr=0x6,drive=drive-virtio-disk0,id=virtio-disk0 -netdev tap,fd=25,id=hostnet0 -device rtl8139,netdev=hostnet0,id=net0,mac=52:54:00:43:bf:8c,bus=pci.0,addr=0x3 -chardev pty,id=charserial0 -device isa-serial,chardev=charserial0,id=serial0 -vnc 0.0.0.0:0 -vga cirrus -device pci-assign,host=15:10.0,id=hostdev0,configfd=26,bus=pci.0,addr=0x4 -device virtio-balloon-pci,id=balloon0,bus=pci.0,addr=0x7 -msg timestamp=on
char device redirected to /dev/pts/1
I can see that virtual function succeeded because I got the following output
virsh net-dumpxml passthrough-eth6
passthrough-eth6
f8fd37cd-3215-e4b0-17b1-0b5515140db9
lspci | grep Intel
15:00.0 Ethernet controller: Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01)
15:00.1 Ethernet controller: Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01)
15:10.0 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
15:10.1 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
And Intel-IOMMU: enabled in the dmesg
From host dmesg
ixgbe 0000:15:00.0: setting MAC 52:54:00:97:c6:86 on VF 0
I can see from different post on this site that if working with sr-iov, i should work with vlan
Is this an obligation to work with vlan if working with sr-iov?
If not according to which parameter will the different vf get the traffic.
Let's say i declare max_vfs=7, how will the traffic be seperated between the vm?
However till i get an answer i tried to work with vlan
And i still don't get traffic in vm, but i see it in the physical interface of the host
I tried to do the following to define the vlan
In virsh edit
In host ip link
23: eth6: mtu 1500 qdisc mq state UP qlen 1000
link/ether 38:ea:a7:8f:fa:98 brd ff:ff:ff:ff:ff:ff
vf 0 MAC 52:54:00:60:7f:57, vlan 44
In guest
modprob 8021q
eth1 Link encap:Ethernet HWaddr 52:54:00:60:7F:57 inet6 addr: fe80::5054:ff:fe60:7f57/64 Scope:Link UP BROADCAST RUNNING PROMISC MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:14 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 b) TX bytes:1156 (1.1 KiB)
eth1.44 Link encap:Ethernet HWaddr 52:54:00:60:7F:57
inet6 addr: fe80::5054:ff:fe60:7f57/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:7 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0
I read a bit more about the card that i am using and
The problem was that it filtered packet because it a trace that i replay and not real traffic
So i changed the mac adress in the pcap file and all packet got into the vm.
Now i have a new question:
Is it possible to do port mirroring while using sriov in the same host and in different host
I am using libvirt
What must i do?
My ethernet card is...
ethtool -i eth6
driver: ixgbe
version: 3.19.1-k
