Hi
We are trying to build ODU-L project and we could build wls_lib and FAPI library.
To build FHI_Lib, we need to set MLOG_DIR, we are not able to find any 'mlog' folder.
We used https://gerrit.o-ran-sc.org/r/o-du/phy.git and https://github.com/intel/FlexRAN.git to clone the code.
We tried setting the MLOG_DIR as /home/user/new_odu/phy/fhi_lib/app/src:/home/user/new_odu/phy/fhi_lib/lib/api, but we see below error.
[user@IA-platform fhi_lib]$ ./build.sh
Number of commandline arguments: 0
MLOG folder is set. Enable MLOG (MLOG_DIR=/home/user/new_odu/phy/fhi_lib/app/src:/home/user/new_odu/phy/fhi_lib/lib/api)
Building xRAN Library
LIBXRANSO = 0
MLOG = 1
Building ./build/libxran.so
RTE_TARGET = x86_64-native-linuxapp-icc
[BUILD] lib : libxran
[CC] /home/user/odu-low/phy/fhi_lib/lib/ethernet/ethdi.o
In file included from /home/user/odu-low/phy/fhi_lib/lib/ethernet/ethdi.c(67):
/home/user/odu-low/phy/fhi_lib/lib/api/xran_mlog_lnx.h(28): catastrophic error: cannot open source file "mlog_lnx.h"
#include <mlog_lnx.h>
compilation aborted for /home/user/odu-low/phy/fhi_lib/lib/ethernet/ethdi.c (code 4)
make: *** [build/obj//home/user/odu-low/phy/fhi_lib/lib/ethernet/ethdi.o] Error 4
"make $COMMAND_LINE MLOG=${MLOG} LIBXRANSO=${LIBXRANSO}" command exited with code 2.
we are following this link: https://docs.o-ran-sc.org/projects/o-ran-sc-o-du-phy/en/latest/Setup-Configuration_fh.html#a-4-install-and-configure-sample-application
Rajisha
Hello Rajisha,
Thank you for posting in the Intel Community.
Since this question involves DPDK, please check with Intel Premier Support for further assistance. See the following for access to Intel Premier Support.
Click the "Access and Log In" to contact the DPDK support https://www.intel.com/content/www/us/en/design/support/ips/training/welcome.html
Please be informed that we will now close this request. Just feel free to post a new question if you may have any other inquiries in the future.
Leonardo C.
