Ethernet Products
4350 Discussions
OFED Drivers for 10Gig-E cards?
Hi--
I've read that the OFED environment supports 10Gig-E, but that I need drivers to plugin to extend the functionality. Do all of Intel's 10Gig-E cards support OFED drivers on Linux or is it a subset? If the latter, which have support?
For context, I'd like to compare SDP over Infiniband to 10Gig-E performance for our application. If there is another type of environment that you recommend instead, please let me know. Thanks!
Eric
Mark_H_Intel
The adapters you will want to look at for comparison are the http://The adapters you will want to look at for comparison are the NetEffect™ Ethernet Server Cluster Adapters./ NetEffect™ Ethernet Server Cluster Adapters. OFED support is available for those adapters. The adapters are availabe for CX4, Direct Attach (DA) twinax copper, or SFP+ SR optics.
Once you get the adapters you want, get the latest drivers at http://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=20867 http://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=20867.
Mark H
Mark_H_Intel
Mark H
Hi--
Thanks Mark for the answer. I've purchased two of these cards and have installed them into two CentOS 6.3 machines. The software has installed without a hitch. Once installed, I did manual configuration similar to what I had done with some Infiniband cards we had, however, the two machines intermittently speak to each other.
Basically what I did to configure them after the software was installed as to execute an "ifconfig ethX 192.168.168.X netmask 255.255.255.0" on both of the machines; when I ping the other machine, sometimes I'm lucky and I get a packet over, but usually, it experiences 100% packet loss ("796 packets transmitted, 0 received, +597 errors, 100% packet loss, time 795909ms").
Looking at TCPDump on those interfaces, I see a bunch of these:
14:13:39.673494 STP 802.1w, Rapid STP, Flags [Proposal], bridge-id 8000.78:fe:3d:57:98:ae.820c, length 43
and a few of these:
14:13:55.891721 ARP, Request who-has 192.168.168.43 tell 192.168.168.42, length 28
If I look at the arp table, the HWaddress was originally unknown. If I force it to a hardware address and then ping, I get:
=== ping
PING 192.168.168.42 (192.168.168.42) 56(84) bytes of data.
64 bytes from 192.168.168.42: icmp_seq=22 ttl=64 time=0.145 ms
64 bytes from 192.168.168.42: icmp_seq=23 ttl=64 time=0.145 ms
64 bytes from 192.168.168.42: icmp_seq=29 ttl=64 time=0.146 ms
--- 192.168.168.42 ping statistics ---
33 packets transmitted, 3 received, 90% packet loss, time 32413ms
And on the other machine I see the some packets getting there:
=== tcpdump
[eyt@machine2 ~]$ sudo /usr/sbin/tcpdump -i eth4
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth4, link-type EN10MB (Ethernet), capture size 65535 bytes
14:17:46.411535 STP 802.1w, Rapid STP, Flags [Proposal], bridge-id 8000.78:fe:3d:57:98:ae.820c, length 43
14:17:48.359763 STP 802.1w, Rapid STP, Flags [Proposal], bridge-id 8000.78:fe:3d:57:98:ae.820c, length 43
14:17:50.344836 STP 802.1w, Rapid STP, Flags [Proposal], bridge-id 8000.78:fe:3d:57:98:ae.820c, length 43
14:17:52.176824 STP 802.1w, Rapid STP, Flags [Proposal], bridge-id 8000.78:fe:3d:57:98:ae.820c, length 43
14:17:53.621149 IP 192.168.168.43 > 192.168.168.42: ICMP echo request, id 14618, seq 22, length 64
14:17:53.621167 IP 192.168.168.42 > 192.168.168.43: ICMP echo reply, id 14618, seq 22, length 64
14:17:54.152565 STP 802.1w, Rapid STP, Flags [Proposal], bridge-id 8000.78:fe:3d:57:98:ae.820c, length 43
14:17:54.621008 IP 192.168.168.43 > 192.168.168.42: ICMP echo request, id 14618, seq 23, length 64
14:17:54.621019 IP 192.168.168.42 > 192.168.168.43: ICMP echo reply, id 14618, seq 23, length 64
14:17:56.035934 STP 802.1w, Rapid STP, Flags [Proposal], bridge-id 8000.78:fe:3d:57:98:ae.820c, length 43
14:17:57.879230 STP 802.1w, Rapid STP, Flags [Proposal], bridge-id 8000.78:fe:3d:57:98:ae.820c, length 43
14:17:59.838295 STP 802.1w, Rapid STP, Flags [Proposal], bridge-id 8000.78:fe:3d:57:98:ae.820c, length 43
14:18:00.622136 IP 192.168.168.43 > 192.168.168.42: ICMP echo request, id 14618, seq 29, length 64
14:18:00.622147 IP 192.168.168.42 > 192.168.168.43: ICMP echo reply, id 14618, seq 29, length 64
14:18:01.658207 STP 802.1w, Rapid STP, Flags [Proposal], bridge-id 8000.78:fe:3d:57:98:ae.820c, length 43
14:18:03.542941 STP 802.1w, Rapid STP, Flags [Proposal], bridge-id 8000.78:fe:3d:57:98:ae.820c, length 43
14:18:05.543580 STP 802.1w, Rapid STP, Flags [Proposal], bridge-id 8000.78:fe:3d:57:98:ae.820c, length 43
But then moments after, I can't ping it anymore. I don't see any interesting messages in the syslog of the machines.
This feels like a configuration issue of some sort, however, I was unable to find further documentation. Any thoughts? Thanks.
Eric
Mark_H_Intel
Can you verify which version of OFED you are using? 1.5.4.1? You might also post whatever details you get from Ethtool on the Ethernet interfaces, e.g. ethtool -i.
The messages make me think that the issue is with the configuration of http://www.cisco.com/en/US/tech/tk389/tk621/technologies_white_paper09186a0080094cfa.shtml RSTP on the swittch, so that you are being blocked at the switch ports. Is there anything in the switch logs that might offer some clues?
I don't have any experience in troubleshooting this type of issue, so I am lookng for someone else who might be able to come up with some ideas.
Mark H
Hi--
I've installed 1.5.4.1. The two machines are directly connected to each-other. I am trying to get these machines downgraded to CentOS 6.2 to see if that could change the problem or not.
ethtool returns the following on both machines:
/sbin/ethtool -i eth4
driver: iw_nes
version: 1.5.0.0
firmware-version: 76.85
bus-info: 0000:04:00.0
Another tool which was fruitful in IB-land was ibv_devinfo which says:
hca_id: nes0
transport: iWARP (1)
fw_ver: 76.85
node_guid: 0012:5503:52d0:0000
sys_image_guid: 0012:5503:52d0:0000
vendor_id: 0x1255
vendor_part_id: 256
hw_ver: 0x5
board_id: NES020 Board ID
phys_port_cnt: 1
port: 1
state: PORT_ACTIVE (4)
max_mtu: 4096 (5)
active_mtu: 1024 (3)
sm_lid: 0
port_lid: 1
port_lmc: 0x00
link_layer: Ethernet
The only difference on the other machine is the noid_guid and sys_image_guid which is "0012:5503:5324:0000".
Thanks for any insight or ideas.
Eric
Hi--
Just to close the loop -- it turns out that the two machines weren't directly connected together and that the issue was something on the switch configuration. It has been addressed and so my basic validation appears to work -- I'm now going to start performance testing this configuration and so I'll let you know if this observation changes. Thanks for your assistance.
Eric
Mark_H_Intel
Hi Eric,
Thanks for the update. I'm looking forward to your testing results.
Mark H
Hi Mark--
How do you configure SDP for these cards? I had installed choice # 4 (see below) and I do not get a libsdp.so or any kernel modules which suggest SDP, and the "/usr/bin/sdpnetstat" OFED utility is not installed.
4) Install Intel driver, RDMA verbs, and MPI componentsProvides accelerated network,Intel Multicast Acceleration, DAPL, andMPI capability for clusters.
In the Infiniband world, the installer would have installed an ib_sdp kernel module and provided a libsdp.so, which from there, I could do add a "LD_PRELOAD=libsdp.so" before the server and client and be able to create an SDP connection between them.
Any insight or pointers? Thanks!
Eric
Mark_H_Intel
I have not been involved directly with any OFED setups, so I am passing on second-hand information that I am getting when I ask the Intel experts. With the NetEffect adapters, you have RDMA (iWARP) support that would help your performance. There is no SDP support in the NetEffect adapter. If you are not going to use RDMA, the X520 adapters might perform better in comparison tests with InfiniBand.
If I find out anything else, I will pass it on.
Mark H
Thanks Mark. I guess my question is less about SDP and more about RDMA.
Under Infiniband, my understanding is that RDMA is only exposed in a few programming models, including the IB-Verbs, MPI, and SDP. Conceptually, SDP can be thought of a TCP stack where if the source and destination ports are capable of the SDP protocol, it will use RDMA to execute the transfer (glossing over lots of detail). The real beauty of SDP is that it doesn't require changes to the applications to be used.
With that in mind, I was expecting that iWARP would somehow need to know who is RDMA capable and who isn't, either explicitly (via configuration) or implicitly. If it is explicit, I'm clearly not configuring this so I would love to know how to do it. If it is implicit, then I would like to know how it is being created and how I could verify that my two hosts are actually iWARPing away.
So far, my performance tests aren't great (i.e.: worst than our 82599EB cards), so I suspect that I'm doing something wrong -- I'm just trying to figure out what that could be.
Eric
Mark_H_Intel
Checking with the expert that I know I am told, SDP is not supported by the NetEffect adapter so no matter how the adapter is setting up RDMA connections, SDP is not going to work.
To check if the NE020 cards are 'iwarping' (i.e. running RDMA traffic), you can look at the extended counters in ethtool –S. RDMA is running if QPs created/destroyed increase.
ethtool –S ethx
CreateQPs: #
DestroyQPs: #
I hope this helps.
Mark H
Hi Mark--
Thanks for the response. Based on your answer, it would seem that iWARP would "just happen"; is that right? Sadly those values are presently 0's
$ sudo /sbin/ethtool -S eth4 | grep QP
ModifyQP Timeouts: 0
CreateQPs: 0
SW DestroyQPs: 0
DestroyQPs: 0
Is there any information to suggest why this could be the case? Please let me know. Thanks.
Eric
Mark_H_Intel
In order to run RDMA, your application must be RDMA-aware, such as through an MPI or written to take advantage of RDMA connections. UNH has a training course on writing applications for RDMA that might be helpful: https://www.openfabrics.org/resources/training/training-offerings.html https://www.openfabrics.org/resources/training/training-offerings.html. If you are running an RDMA application on the NetEffect adapter and need help configuring your environment, a good first place to start would be the RDMA latency and bandwidth tests packaged in the OFED distribution.
I am going to send you an email to continue the troubleshooting.
Mark H
