Ethernet Products
5610 Discussions
Omni-Path HFI Silicon 100 Series ethernet support
brtbrt
Do "Omni-Path HFI Silicon 100 Series" cards support ethernet for layer-2?
As below it is infiniband for both of the ports.
The other ends of the cables are ethernet.
[root@casnode04 ~]# ip a
6: ib0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 65520 qdisc pfifo_fast state DOWN group default qlen 256
link/infiniband 80:00:00:02:fe:80:00:00:00:00:00:00:00:11:75:01:01:78:46:7b brd 00:ff:ff:ff:ff:12:40:1b:80:00:00:00:00:00:00:00:ff:ff:ff:ff
inet 10.228.200.173/22 brd 10.228.203.255 scope global noprefixroute ib0
valid_lft forever preferred_lft forever
7: ib1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 65520 qdisc pfifo_fast state DOWN group default qlen 256
link/infiniband 80:00:00:02:fe:80:00:00:00:00:00:00:00:11:75:01:01:78:26:c0 brd 00:ff:ff:ff:ff:12:40:1b:80:00:00:00:00:00:00:00:ff:ff:ff:ff
inet 10.228.250.173/22 brd 10.228.251.255 scope global noprefixroute ib1
[root@casnode04 ~]#
[root@casnode04 ~]#
[root@casnode04 ~]# ibstat
CA 'hfi1_0'
CA type:
Number of ports: 1
Firmware version: 1.27.0
Hardware version: 11
Node GUID: 0x001175010178467b
System image GUID: 0x001175010178467b
Port 1:
State: Down
Physical state: ???
Rate: 100
Base lid: 0
LMC: 0
SM lid: 0
Capability mask: 0x00490020
Port GUID: 0x001175010178467b
Link layer: InfiniBand
CA 'hfi1_1'
CA type:
Number of ports: 1
Node GUID: 0x00117501017826c0
Port 1:
State: Down
Physical state: ???
Rate: 100
Base lid: 0
LMC: 0
SM lid: 0
Port GUID: 0x00117501017826c0
[root@casnode04 ~]#
*-network
description: interface
product: Omni-Path HFI Silicon 100 Series [discrete]
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:82:00.0
logical name: ib1
version: 11
serial: 80:00:00:02:fe:80:00:00:00:00:00:00:00:11:00:00:00:00:00:00
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msix bus_master cap_list rom physical
configuration: autonegotiation=off broadcast=yes driver=ib_ipoib driverversion=1.0.0 firmware=1.27.0 ip=10.228.250.173 latency=0 multicast=yes port=twisted pair
resources: irq:35 memory:f4000000-f7ffffff memory:f8000000-f801ffff
Achilles_Intel
Hello brtbrt,
Thank you for posting in Intel Customer Support.
Please be informed that Omni-Path Fabric Products are now supported by Cornelis Networks. For your convenience, you can reach out to them using this link below.
https://www.cornelisnetworks.com/support/
Let us know if you have further questions or need clarifications. We will keep this thread open for 3 business days. In case we do not receive any response from you, we will proceed in closing this thread.
Thank you and have a nice day.
Achilles M.
Achilles_Intel
Hello brtbrt,
How are you?
We are following up on your inquiry for this thread. Since we haven't heard from you in a few days, we will now close this thread. Feel free to post a new question in the forums if you have need further assistance again in the future as this thread will no longer be monitored.
Achilles M.
