Ethernet Products
4361 Discussions
Persistently Capturing Packets with VLAN Tags with Intel Pro/1000 CT NIC Card In CentSO 6.3
I am in need to capture packets that contain VLAN tags on my Intel Pro/1000 CT NIC Card.
When I try to capture packets using the command: tcpdump -ni eth2 vlan
I do NOT capture any packets.
I then issue the command: ifconfig eth2 mtu 1522
I then try to capture packets using the command: tcpdump -ni eth2 vlan
I CAN now capture packets
I then save my settings in my cfg file: /etc/sysconfig/network-scripts/ifcfg-eth2
# Please read /usr/share/doc/initscripts-*/http://sysconfig.txt/ sysconfig.txt
# for the documentation of these parameters.
DEVICE=eth2
BOOTPROTO=none
NETMASK=255.255.255.0
TYPE=Ethernet
IPADDR=10.2.1.1
HWADDR=00:1b:21:a0:17:27
MTU=1522
I then reboot the computer.
After the reboot I issue the command: tcpdump -ni eth2 vlan
Now NO packets are captured.
I check the interface settings using: ifconfig eth2
The MTU setting is still there:
ifconfig eth2
eth2 Link encap:Ethernet HWaddr 00:1B:21:A0:17:27
inet addr:10.2.1.1 Bcast:10.2.1.255 Mask:255.255.255.0
inet6 addr: fe80::21b:21ff:fea0:1727/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1522 Metric:1
RX packets:2 errors:0 dropped:0 overruns:0 frame:0
TX packets:26 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:120 (120.0 b) TX bytes:4181 (4.0 KiB)
Interrupt:17 Memory:f0680000-f06a0000
I then issue the command: ifconfig eth2 mtu 1524 and ifconfig eth2 mtu 1522
(Toggling the MTU setting)
Any idea how to make the ability to capture packets permanent between reboots?
Thanks in advance for any wisdom and guidance!!
-John
Various settings:
ifconfig eth2
ethtool -i eth2
driver: e1000e
version: 1.9.5-k
firmware-version: 1.8-0
bus-info: 0000:30:00.0
modinfo -d -p e1000e
EEE:Enable/disable on parts that support the feature
CrcStripping:Enable CRC Stripping, disable if your BMC needs the CRC
WriteProtectNVM:Write-protect NVM [WARNING: disabling this can lead to corrupted NVM]
KumeranLockLoss:Enable Kumeran lock loss workaround
SmartPowerDownEnable:Enable PHY smart power down
IntMode:Interrupt Mode
InterruptThrottleRate:Interrupt Throttling Rate
RxAbsIntDelay:Receive Absolute Interrupt Delay
RxIntDelay:Receive Interrupt Delay
TxAbsIntDelay:Transmit Absolute Interrupt Delay
TxIntDelay:Transmit Interrupt Delay
copybreak:Maximum size of packet that is copied to a new buffer on receive
lspci
20:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
30:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
ethtool eth2
Settings for eth2:
Supported ports: [ TP ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Speed: 1000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 1
Transceiver: internal
Auto-negotiation: on
MDI-X: off
Supports Wake-on: pumbg
Wake-on: g
Current message level: 0x00000001 (1)
Link detected: yes
Mark_H_Intel
Were you able to resolve this issue? What have you tried since posting here? I asked around, but no one was aware of any related bugs or had ideas about why you had to make MTU changes to allow the capture to work.
Mark H
