Ethernet Products
4811 Discussions
Problem IProsetMonitor.exe
JHoki
Hello
I have problem intel drivers I350-T2 for Microsoft Windows 2012.
Sometime service stop Intel(R) PROSet Monitoring Service.
In event write message:
Log Name: Application
Source: Application Error
Date: 27.01.2016 12:37:37
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: VCS4H.ascon.ru
Description:
Faulting application name: IProsetMonitor.exe, version: 20.3.44.0, time stamp: 0x55c3b29e
Faulting module name: ntdll.dll, version: 6.2.9200.17581, time stamp: 0x5644f0f7
Exception code: 0xc0000374
Fault offset: 0x00000000000e9d19
Faulting process id: 0x1684
Faulting application start time: 0x01d158e1847d87b6
Faulting application path: C:\Windows\system32\IProsetMonitor.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: 995224c2-c4d9-11e5-9422-0cc47a31ddf5
Faulting package full name:
Faulting package-relative application ID:
Event Xml:
http://schemas.microsoft.com/win/2004/08/events/event http://schemas.microsoft.com/win/2004/08/events/event">
1000
2
100
0x80000000000000
2490
Application
VCS4H.ascon.ru
IProsetMonitor.exe
20.3.44.0
55c3b29e
ntdll.dll
6.2.9200.17581
5644f0f7
c0000374
00000000000e9d19
1684
01d158e1847d87b6
How it is possible to solve this problem?
Two servers in a cluster, a problem only in start of service Intel(R) PROSet Monitoring Service.
Whether if problems with operation of drivers of the network interface card are to stop this service?
SYeo3
Valued Contributor I
Hi JimyHokins,
Thank you for contacting Intel.
Please try to uninstall then re-install the Intel® PROSet Software. Hope this can help resolve the problem.
Sincerely,
Sandy
JHoki
Hi
I make re-install Intel ProSet Software.
On servers install Role Hyper-V 2012.
Service Intel(R) PROSet Monitoring Service start - ok, but only on host not virtual machine.
If I migrate VM with other host Hyper-V, on service is stop error.
The Best Regard
SYeo3
Hi JimyHokins,
This issue maybe caused by the driver. Please provide your network card's serial number so I can check the card's version against the driver.
Format of Serial Number: 12-digit 5-digit 6-3digit number
Photo of http://www.intel.com/content/www/us/en/support/boards-and-kits/000005625.html# Lnp Intel Network Card
Sincerely,
Sandy
JHoki
Hi Sandy
I have two adapters with two others servers.
Intel Ethernet Server Adapter I350-T2
I350T2V2BLK
A0369F7142AC145ADH47819-001
I have typy network on mb Supermicro X10DRW-i.
Install driver version 12.14.7.0 now.
The Best Regard,Jimy
