Ethernet Products
4864 Discussions
Problem upgrading the firmware on XL710 card
AIsto2
Hello!
I've seen a /thread/87145?start=0&tstart=0 thread about firmware update and tried both versions of NVMUpdate mentioned there , but neither tool detects my card (ignore X540 one)
[root@server ~/intel_firmware/XL710_1.0]$ ./nvmupdate64e
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.24.33.08
Copyright (C) 2013 - 2015 Intel Corporation.
WARNING: TO AVOID DAMAGE TO YOUR DEVICE, DO NOT EXIT OR REBOOT OR POWER OFF THE SYSTEM DURING THIS UPDATE
Inventory in progress. Please wait [+.........]
Num Description Device-Id B:D Adapter Status
01) Intel(R) Ethernet Controller X540-AT2 8086-1528 04:00 Update not available
02) Intel(R) Ethernet Converged Network Ad 8086-1583 129:00 Update not available
Tool execution completed with the following status: All operations completed successfully
[root@server ~/intel_firmware/XL710_1.0]$ cd ../XL710_1.25/
[root@server ~/intel_firmware/XL710_1.25]$ ./nvmupdate64e
NVMUpdate version 1.25.20.12
Press any key to exit.
Details on the adapter
[root@server ~]$ lspci -n|grep -E "81:00.0|81:00.1"
81:00.0 0200: 8086:1583 (rev 01)
81:00.1 0200: 8086:1583 (rev 01)
[root@server ~]$ lspci -v|grep -E "81:00.0|81:00.1"
81:00.0 Ethernet controller: Intel Corporation Ethernet Controller XL710 for 40GbE QSFP+ (rev 01)
81:00.1 Ethernet controller: Intel Corporation Ethernet Controller XL710 for 40GbE QSFP+ (rev 01)
From dmesg (RHEL7.2, 3.10.0-327.3.1.el7.x86_64)
i40e: Intel(R) Ethernet Connection XL710 Network Driver - version 1.3.21-k
i40e: Copyright (c) 2013 - 2014 Intel Corporation.
i40e 0000:81:00.0: f4.1.24827 a1.1 n4.10 e10e0
i40e 0000:81:00.0: The driver for the device detected an older version of the NVM image than expected. Please update the NVM image.
i40e 0000:81:00.0: Stopping firmware LLDP agent.
i40e 0000:81:00.0: MAC address: 68:05:ca:27:ab:f4
i40e 0000:81:00.0: enabling bridge mode: VEPA
i40e 0000:81:00.0: i40e_ptp_init: added PHC on eth0
i40e 0000:81:00.0: PCI-Express: Speed 8.0GT/s Width x8
i40e 0000:81:00.0: Features: PF-id[0] VFs: 64 VSIs: 66 QP: 48 RX: 1BUF RSS FD_ATR FD_SB NTUPLE PTP
i40e 0000:81:00.1: f4.1.24827 a1.1 n4.10 e10e0
i40e 0000:81:00.1: The driver for the device detected an older version of the NVM image than expected. Please update the NVM image.
i40e 0000:81:00.1: Stopping firmware LLDP agent.
i40e 0000:81:00.1: MAC address: 68:05:ca:27:ab:f5
i40e 0000:81:00.1: enabling bridge mode: VEPA
i40e 0000:81:00.1: i40e_ptp_init: added PHC on eth1
i40e 0000:81:00.1: PCI-Express: Speed 8.0GT/s Width x8
i40e 0000:81:00.1: get phy capabilities failed, err I40E_ERR_UNKNOWN_PHY aq_err I40E_AQ_RC_EIO, advertised speed settings may not be correct
i40e 0000:81:00.1: Features: PF-id[1] VFs: 64 VSIs: 66 QP: 48 RX: 1BUF RSS FD_ATR FD_SB NTUPLE PTP
i40e 0000:81:00.0 ens5f0: NIC Link is Up 40 Gbps Full Duplex, Flow Control: RX/TX
i40e 0000:81:00.1 ens5f1: NIC Link is Up 40 Gbps Full Duplex, Flow Control: RX/TX
st4
New Contributor III
Hi Alecl,
Have you tried using this NVMeUpdate tool? https://downloadcenter.intel.com/download/25222/NVM-Update-Utility-for-Intel-Ethernet-Converged-Network-Adapter-XL710-X710-Series Download NVM Update Utility for Intel® Ethernet Converged Network Adapter XL710 & X710 Series
AIsto2
Yes, I tried and in both cases I got the message "Update not available" (see original post with exact output)
AIsto2
Quick follow up - the download you mentioned is version 1.24.33.08, not version "1" mentioned in the thread - so maybe I need a version of NVMeUpdate earlier than 1.24.33.08?
st4
New Contributor III
Hi AlecL,
Let me check on this.
rgds,
wb
st4
New Contributor III
Hi AlecL,
Just to double check ,what is the serial number of your XL710? Here is the website where you can locate the serial number location:
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000005584.html Identify Your Wired Ethernet Adapter and Driver Version for Network...
rgds,
wb
AIsto2
WB,
The only sticker I found says:
6805CA27A9CC
012 181407
H29452-004
Alec
st4
New Contributor III
Hi Alec,
Thank you for information. Based on the marking this is an OEM X710 network adapter, you may contact the OEM vendor for the firmware.
rgds,
wb
AIsto2
WB, thanks for the info... i will try the version from supermicro, but quick search shows they use similar (possibly the same) xl710 nveupdate package
Please let me know if you have any suggestions on how to upgrade firmware, maybe even older versions of firmware tool - i'd appreciate it...
I want to make sure I'm using the latest firmware, as currently I experience performance and stability issues with the adapter under heavy load (~33G). Kernel message indicate that TX queues "crash" and adapter disappears form the system, so that the server has to be powered off to bring it back (reboot does not help)
AIsto2
I was not able to find the mention of current ETrackId: 800010E0 in any of the updates so far, let me know if there is any chance you can help upgrade from this one.
$ ./nvmupdate64e -i -l
[129:00:00]: Intel(R) Ethernet Converged Network Adapter XL710-Q2
LAN MAC: redacted
Alt MAC: 000000000000
SAN MAC: redacted
EEPROM: ETrackId: 800010E0, Checksum valid
VPD: Size: 32
Flash: Size: 4194304, CIVD: 0.0.0
Vendor: 8086 Device: 1583 Subvendor: 8086 Subdevice: 1 Revision: 1
[129:00:01]: Intel(R) Ethernet Converged Network Adapter XL710-Q2
LAN MAC: redacted
SAN MAC: redacted
VPD: Size: 32
Vendor: 8086 Device: 1583 Subvendor: 8086 Subdevice: 0 Revision: 1
st4
New Contributor III
HI Alecl,
The one available on our website is the version available so far, have you check with Supermicro?
thanks,
wb
AIsto2
Yes, they provide similar package, with slightly earlier version of nvmupdate.
