I have a problem with the installation of the Intel PRO 1000 PT dual port on a Win 10 PC.
When I open SetupDB.exe with administrative rights, it says that there are no Intel NICs present on the system.
Windows already displays the 2 adapters on the devmgmt.msc and installed the default drivers.
Although the adapter works with the default win drivers, I want to use the ANS options for teaming.
I downloaded the latest driver for Win 10 x64.
Is this a known issue or is there any work around for this?
Many thanks
Chris
Hi Chris_PT,
Thank you for the post. We do not have Windows* 10 driver or ANS software available for download for PT Server Adapter, you may refer to link for reference
https://downloadcenter.intel.com/product/50497/Intel-PRO-1000-PT-Server-Adapter Intel® Download Center
If you are refering to the driver available at https://downloadcenter.intel.com/download/25016/Network-Adapter-Driver-for-Windows-10 https://downloadcenter.intel.com/download/25016/Network-Adapter-Driver-for-Windows-10- , this driver is only applicable for below products:
- https://downloadcenter.intel.com/product/47549/Intel-82579-Gigabit-Ethernet-Controller Intel® 82579 Gigabit Ethernet Controller
- https://downloadcenter.intel.com/product/32609/Intel-82599-10-Gigabit-Ethernet-Controller Intel® 82599 10 Gigabit Ethernet Controller
- https://downloadcenter.intel.com/product/60019/Intel-Ethernet-Connection-I217-LM Intel® Ethernet Connection I217-LM
- https://downloadcenter.intel.com/product/70831/Intel-Ethernet-Connection-I217-V Intel® Ethernet Connection I217-V
- https://downloadcenter.intel.com/product/71307/Intel-Ethernet-Connection-I218-LM Intel® Ethernet Connection I218-LM
- https://downloadcenter.intel.com/product/71305/Intel-Ethernet-Connection-I218-V Intel® Ethernet Connection I218-V
- https://downloadcenter.intel.com/product/64399/Intel-Ethernet-Controller-I210-Series Intel® Ethernet Controller I210 Series
- https://downloadcenter.intel.com/product/64403/Intel-Ethernet-Controller-I211-Series Intel® Ethernet Controller I211 Series
- https://downloadcenter.intel.com/product/59679/Intel-Ethernet-Controller-I350-Series Intel® Ethernet Controller I350 Series
- https://downloadcenter.intel.com/product/60020/Intel-Ethernet-Controller-X540-AT2 Intel® Ethernet Controller X540-AT2
- https://downloadcenter.intel.com/product/68668/Intel-Ethernet-Server-Adapter-I210-T1 Intel® Ethernet Server Adapter I210-T1
- https://downloadcenter.intel.com/product/59062/Intel-Ethernet-Server-Adapter-I350-T2 Intel® Ethernet Server Adapter I350-T2
- https://downloadcenter.intel.com/product/59063/Intel-Ethernet-Server-Adapter-I350-T4 Intel® Ethernet Server Adapter I350-T4
thanks,
wb
