Ethernet Products
5821 Discussions
Problem with Installation of Intel PRO 1000 PT
CSchl3
I have a problem with the installation of the Intel PRO 1000 PT dual port on a Win 10 PC.
When I open SetupDB.exe with administrative rights, it says that there are no Intel NICs present on the system.
Windows already displays the 2 adapters on the devmgmt.msc and installed the default drivers.
Although the adapter works with the default win drivers, I want to use the ANS options for teaming.
I downloaded the latest driver for Win 10 x64.
Is this a known issue or is there any work around for this?
Many thanks
Chris
st4
New Contributor III
Hi Chris_PT,
Thank you for the post. We do not have Windows* 10 driver or ANS software available for download for PT Server Adapter, you may refer to link for reference
https://downloadcenter.intel.com/product/50497/Intel-PRO-1000-PT-Server-Adapter Intel® Download Center
If you are refering to the driver available at https://downloadcenter.intel.com/download/25016/Network-Adapter-Driver-for-Windows-10 https://downloadcenter.intel.com/download/25016/Network-Adapter-Driver-for-Windows-10- , this driver is only applicable for below products:
thanks,
wb
