Ethernet Products
5527 Discussions
Problem with Intel 82579V Gigabit Network Driver
RPatr1
The driver is not working after cold boot / reboot. I've tried different versions of the driver. I've tried so far:
  1. Disabling power saving functions.
  2. https://answers.microsoft.com/en-us/windows/forum/windows_10-networking-winpc/ethernet-connection-on-intel-82579v-gigabit-fails/644ddcbe-9235-4399-8a43-79e4bc7ccc8e Ethernet connection on Intel 82579V Gigabit fails on start-up until I - Microsoft Community
The problem has still persists. Any suggestions?
AlHill
You can find the latest drivers here: https://ark.intel.com/products/52963/Intel-82579V-Gigabit-Ethernet-PHY Intel® 82579V Gigabit Ethernet PHY Product Specifications
If that does not work, download and run this utility, then attach the results:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Download Intel® System Support Utility for Windows*
Then, one of the Intel support engineers will be able to assist you.
Doc
RPatr1
SSU Report attached.
Hello DistortedVision,
Thank you for posting in Intel Wired Ethernet Communities. This is an Ethernet Controller integrated into an ASUS motherboard. Have you checked with ASUS for drivers? We recommend the drivers from the motherboard manufacturer for this type of device. Please let us know if ASUS is able to assist you with this, and if you have any other questions.
Daniel D
Intel Customer Support
Agent under contract to Intel
Have you contacted ASUS, and have they been able to supply the driver? Please let us know if you are still encountering an issue with the 82579V Gigabit Ethernet Controller.
Daniel D
RPatr1
I'm unable to resolve the issue. I bought a PCI-E NIC.
Problem resolved.
Thank you for the reply. Sorry we could not provide a driver to resolve this issue. Please let us know if you have any other questions.
Daniel D
