Ethernet Products
5821 Discussions
Problem with Intel WiFi Link 5100 AGN - Not connecting
I have the following problem:
I have a laptop that uses the wifi link 5100 agn and I recently upgraded from Vista to 7.
In Vista everything worked fine, however now I cannot connect to my network(even though it is listed on the "Available Networks").
In order to test if the problem was the password encryption or even if I had to switch from WPA to WEP, I set my router to unsecure, nevertheless it wouldn't connect.
Finally, I set static IP (in order to see if the problem was the DHCP), but still the problem remains.
I have the latest driver from the website.
The IntelPro pointed out that the problem is on the association phase, however the troubleshooting available there didn't help.
I'm using Windows 7 Professional and I'm trying to connect to a Thomson TG858 v7 router.
Does anyone have any idea on what to do next?
Thanks in advance!
