Ethernet Products
5775 Discussions
Problem with X520-2 and HP X240 DA cable
I'm trying to use a pair of X520-2 cards under Win7 64bit machines with an HP X240 (JD097B) 3m DA cable.
The cards seems to refuse to work with this cable, windows is logging "The driver was unable to load due to an unsupported SFP+ module installed in the adapter".
I tried to switch ports and with a HP ProCurve switch(2910al) and got the same results.
Connecting the cards with a Intel SFP+ SR module in each one seems to work just fine.
Any thought?
Thanks in advance!
what is the exact x520-2 server adapter you are using??? You may want to check this info from Intel website
http://www.intel.com/support/network/adapter/pro100/sb/CS-030612.htm http://www.intel.com/support/network/adapter/pro100/sb/CS-030612.htm
