Hi i have the modo intel z77 dz77ga-70k i have issues with both ethernet adapters disable it at random i try reinstal drivers i try the latest i try the ms drivers nothing i have win 10 pro x64
Hi jim_jimas,
Thank you for posting your query in Wired Ethernet Communities.
Please share the issue and error message you encountered with the Ethernet adapter, we'd also like to request for the Ethernet adapter model installed in your dz77ga-70k mobo.
Additional isolation you could perform is install another Ethernet adapter to check if encountered the same issue.
regards,
Vince
Hi jim_jimas,
We'd like to check if you still need assistance regarding your issue.
regards,
Vince
