Hello
Form several days we have a problem with quad cards on debian squeeze and module igb.
This cards are connected to two diffirent networks but we have random error, dropped and frame packets on random interfaces.
Has anyone had similar problem ?
output:
uname -a
Linux db3 2.6.38.8 # 2 SMP Wed Feb 22 11:29:33 CET 2012 x86_64 GNU/Linux
lspci
4:00.0 Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01)
04:00.1 Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01)
06:00.0 Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01)
06:00.1 Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01)
modinfo igb
filename: /lib/modules/2.6.38.8/kernel/drivers/net/igb/igb.ko
version: 2.1.0-k2
license: GPL
description: Intel(R) Gigabit Ethernet Network Driver
author: Intel Corporation, <</span>mailto:e1000-devel@lists.sourceforge.net e1000-devel@lists.sourceforge.net>
srcversion: 586C8F9095F77398E61AEAB
alias: pci:v00008086d000010D6sv*sd*bc*sc*i*
alias: pci:v00008086d000010A9sv*sd*bc*sc*i*
alias: pci:v00008086d000010A7sv*sd*bc*sc*i*
alias: pci:v00008086d000010E8sv*sd*bc*sc*i*
alias: pci:v00008086d00001526sv*sd*bc*sc*i*
alias: pci:v00008086d0000150Dsv*sd*bc*sc*i*
alias: pci:v00008086d000010E7sv*sd*bc*sc*i*
alias: pci:v00008086d000010E6sv*sd*bc*sc*i*
alias: pci:v00008086d00001518sv*sd*bc*sc*i*
alias: pci:v00008086d0000150Asv*sd*bc*sc*i*
alias: pci:v00008086d000010C9sv*sd*bc*sc*i*
alias: pci:v00008086d00000440sv*sd*bc*sc*i*
alias: pci:v00008086d0000043Csv*sd*bc*sc*i*
alias: pci:v00008086d0000043Asv*sd*bc*sc*i*
alias: pci:v00008086d00000438sv*sd*bc*sc*i*
alias: pci:v00008086d00001516sv*sd*bc*sc*i*
alias: pci:v00008086d00001511sv*sd*bc*sc*i*
alias: pci:v00008086d00001510sv*sd*bc*sc*i*
alias: pci:v00008086d0000150Fsv*sd*bc*sc*i*
alias: pci:v00008086d0000150Esv*sd*bc*sc*i*
alias: pci:v00008086d00001524sv*sd*bc*sc*i*
alias: pci:v00008086d00001523sv*sd*bc*sc*i*
alias: pci:v00008086d00001522sv*sd*bc*sc*i*
alias: pci:v00008086d00001521sv*sd*bc*sc*i*
depends: dca
vermagic: 2.6.38.8 SMP mod_unload modversions
parm: max_vfs:Maximum number of virtual functions to allocate per physical function (uint)
Best regards
Sebastian Stach
- Tags:
- Intel® Ethernet
