Hi i'm using this adapter for an industrial application and the two ports is wired directly to two other pc:s. It's working fine however every now and then (maybe once a week) the connection is lost between one port of the EXPI9402PT and one pc. The connection seems to be completely dead as the leds of the adapter stops flashing. A simple reboot of the comuter fixes this issue! It is very imortant that this connection runs at 1gbit all the time so the connection speed of the card is set so. The system is running windows xp and i dont know exactly what version of the driver is yet. (will find out later)
I haven't had any chance to investigate further as the operators reboots the computers as soon as this problem occurs.. But is this a known issue? Should i replace the card with some other model??
Edit: It can of course be the integrated network of the other pc's mobo. I have a couple of intel PRO/1000 GT desktop on order to try it out. I will also have to check if it's heat related. Do you have any other suggestions of what i can try? I can try to replicate the problem by doing a stress test and then try to find out which card is locking up...?
Have you checked the power management settings for any of these systems? Try disabling power management for the adapter and LAN ports on the other two machines. Once you find out what driver version you are using, that would be helpful. In addition, do you have any special settings of configurations applied to the Ethernet ports? It would be helpful to get those details as well.
All the power savers are disabled, the version of the intel proset is 16.3.48.0 and the driver version is 9.13.41.0, there are much more newer drivers but only for windows 7 and they wont install on xp..!
Hi Brillfors,
If the 2 systems are on the same speed (1Gbps), you may try disabling Flow Control on all ports. This feature manages the transmission so the faster port will not overwhelm the slower port.
Will try that thanks. Is there any way to extract the drivers from the installer to get them running on a 32-bit xp system?
Hi Brillfors, I've tried using 7-zip to extract the installer to folders, xp 32-bit driver downloaded from https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=18717 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=18717
hope this helps.
Thanks is that the correct drivers? i cant see the PT dual port server adapter in there... If i search the download center i cant find a single driver for xp.
unfortunately, winXP is not under the supported list of OS for PT Dual port, kindly refer to the product brief - http://www.intel.ph/content/www/ph/en/network-adapters/gigabit-network-adapters/1000-pt-dual-port-se... Intel® PRO/1000 PT Dual Port Server Adapter Product Brief .
