Ethernet Products
5508 Discussions
Prowin32 unbundled
Is there a way to unbundle Prowin32? I need to extract the win7 driver for our Dell systems as the one from Dell has issues and has to be updated using Prowin32 after we image a PC..Any help or advice would be appreciated..
Thanks in Advance
David
Mark_H_Intel
Hi David,
The executables are in a format that can be extracted by programs such as WinZip or WinRAR. You can also extract the files from the executable using command line switches as explained in the readme. I copied out the information you need below:
This self extracting archive supports the following command line parameters:
ParameterDescription
/f
Destination path where the archived files will be extracted to.
/e
Do not automatically start the installation process.
/s
Extract the files silently.
For example, to only extract the contents of the webpack to a specific folder (and not run the installation), type the following:
/f /s /e
NOTE: The /f parameter must precede the /e parameter. Failure to do so may cause an "Unable to execute the specified command line!" error.
Have a great day!
Mark H
Mark_H_Intel
Hi David,
/f
/e
/s
/f /s /e
Have a great day!
Mark H
TOO EASY..
Thank you very much..
d
