Ethernet Products
5506 Discussions
QSFP+ Configuration modification is not supported by this adapter
HuntPackets
I am trying to set up Intel XL710 in 4x10 mode using QCU but I get the error "QSFP+ Configuration modification is not supported by this adapter".  It is currently functioning in 2x40 mode
When I use qcu64e /devices I get the error "Error: Invalid image on the adapter."
I have several XL710 that do not have this error.  Including the XL710 with the error, all are using Fiberstor Intel compatible QSFP+ tranceiver module
This is my firmware and driver info:
# ethtool -i eth2
driver: i40e
version: 2.17.4
firmware-version: 7.10 0x800075ec 19.5.12
expansion-rom-version:
bus-info: 0000:02:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
The numbers on my NIC, that include PBA number are:
F8F21EC80EE0
016  4220AD
H87409 - 007
Please help me resolve this issue
Sazirah
Hi HuntPackets,
Upon checking, you have contacted us regarding this issue and have opened a separate case that we are currently assisting. We will continue to assist you in that case for now.
This forum thread will be close as we will monitor the issue progress in other case.
Sazzy_Intel
