Ethernet Products
4628 Discussions
Quad Port product Differences
JMich15
I am trying to determine what the technical differences are between the E1G44ET and the E1G44ET2. Both are quad port RJ45 GigE adapters ad use the same asic, 82576. Anybody have any info on this ?
thanks in advance,
jim
Refer to these links:
http://www.intel.com/support/network/sb/CS-012904.htm
http://www.intel.com/Assets/PDF/prodbrief/320116.pdf
All the best,
Kind Regards,
Aryan.
/poll.jspa?poll=1138 Voting Poll
Patrick_K_Intel1
The ET2 has support for the PCI SIG SR-IOV Virtualization Technology. If you are unfamiliar with SR-IOV there is another blog about this technology:
/community/wired/blog/2010/09/07/sr-iov-explained http://communities.intel.com/community/wired/blog/2010/09/07/sr-iov-explained
JMich15
Okay, reading between the lines the difference is a change to the PCIe Switch (bridge) used.
thanks,
jim
Mark_H_Intel
