Ethernet Products
5770 Discussions
Query: Programming of Intel I210-Device ID # 1531
ST_L
Hi Intel Community,
I am using Intel I210-IT (Device ID: 1531) in my board. In the Intel Ethernet Controller Specification update document Version 2.5, Page No. 6 Table1-2 it is mentioned that, Device ID 1531 is for Not Programmed/Factory Default. If I want to use the device, whether i need to program the device or not? If yes how to program the device?
Santhana Krishnan T L
Daniel_D_Intel1
Hello STL, Thank you for posting in Intel Ethernet Communities. The following thread has the answer to a similar question: https://forums.intel.com/s/question/0D50P00004905tKSAQ/i210it-operation For more detailed explanation or further questions please check the Embedded Community: https://forums.intel.com/s/topic/0TO0P00000018NHWAY Let us know if you have any other questions. Best regards, Daniel D Intel Customer Support
