Ethernet Products
5736 Discussions
Question regarding RSS Profile as default on Driver(I350)
SHWAN6
Installed Windows 2012 R2 : RSS Profile : NUMAStatic (Default)
After Installed NIC Driver(I350 4 Port) : RSS Profile : Closest
I want to know why Intel sets RSS Profiles to Closest.
Closest was default value on Windows 2008/R2.
If you just don't change from Windows 2008/R2, it is fine. I can change.
But I need to know there is any reason.
Actually I need to change to NUMAStatic, but I have concern about to change RSS Profile, if there is any reason to set "Closest' as default.
Hi Kuwit,
Thank you for posting in Wired Communities. I will further check for you.
Sharon
Hi Kuwit,
The reason RSS profile is set to "Closest" as default is to improve CPU utilization. If you wish to use NUMAstatic, this is also supported, you can refer to below website for reference:
https://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000006703.html
Sharon
Hi Kuwit,
Please feel free to update me if you still have other inquiries or clarification. Thanks.
Sharon
SHWAN6
Thanks for the answer.
I already read one of known issues which in you answer
I'm curious for that even there are known issues, does Intel sets closest to improve CPU utilization for Windows Server 2012/R2?
One more question about RSS Profile
Tested on below system
- HP DL360 Gen9 (2667 v4 * 2ea)
- 1GB 4port 366FLR (Intel/1G*2ea Team/LACP)
- Windows 2012 R2 Standard
- RSS : Enabled
- RSS Queue : 8
I expect 16 queues will working with "Closest"
But result is below.
Closest - around 8 queues work
ClosestStatic - 16 queues work
NUMA - around 12 queues work
NUMAStatic - 16 queues work
Is this result correct you designed?
HI Kuwit,
Thank you for the update. Yes, this is to reduce CPU utilization. For the results, can you share what are the commands with the parameter you executed?
Sharon
SHWAN6
I can not see clear what do you ask for, I answer both which I understand.
To set RSS configuration,
NIC properties of "Device Manager" or Set-NetAdapterRss -Profile "OO" on powershell.
To make load
https://gallery.technet.microsoft.com/NTttcp-Version-528-Now-f8b12769 https://gallery.technet.microsoft.com/NTttcp-Version-528-Now-f8b12769
Hi Kuwit,
Thank you for the information. What I refer to is the command you run to get the result and please run the SSU (downloadable at link below) and send me the log file. Thank you.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Sharon
SHWAN6
The server was only for testing, I already reset whole things even OS.
It means I can not give you a log which you requested.
I asked about your RSS design of profiles.
By the way, let me know what do you want get more information.
Hi Kuwit,
Thank you for the update. I will try to check based on the information and will update you if I need more information.
Sharon
Hi Kuwit,
Further checking, since the "closest" is dynamic, it will change based on load, hardware configuration, environment, and other things running on the system and the network.
In order to come up with best performance, this should be done with the actual data and load expected while monitoring a number of factors such as CPU, RAM, and disk utilization among other things.
Sharon
SHWAN6
Hello Sharon,
Thanks for the answer. It helps me.
I wonder if you have a document about to define RSS Profile(Including dynamic or not).
I couldn't find it.
Hi Kuwit,
You are welcome. You may refer to our User guide for some reference information but it did not have specific information about including dynamic or not.
Here is the reference download link:
https://downloadcenter.intel.com/download/11848/User-Guides-for-Intel-Ethernet-Adapters
You may refer to the Microsoft website for additional information.
https://technet.microsoft.com/en-us/library/hh997036(v=ws.11).aspx
(Please note this is third party website for your reference only, Intel has no control over the web content)
Hope the information helps.
Sharon
Hi Kuwit,
Please do let me know if the information helps and if you still have other inquiries.
Sharon
SHWAN6
I want to get a document about to have specific information about including dynamic or not.
but if you don't have or can not see, you can close this.
I also try to find that but can not.
By the way thanks for the all answers and supports.
Everything helps me.
Thanks a lot, Sharon.
Hi Kuwit,
You are welcome and thank you for the reply. I do not have the information, I will try check in case there is information to share.Thanks.
Sharon
Hi Kuwit,
I am sorry to inform you there is no further information available. Thank you for your time on this matter.
Sharon
