Ethernet Products
5719 Discussions
RE: EYE810XXVAM2 Pcie to Ethernet controller
Niranjan_1
We are planning to use the Intel® Ethernet Controller E810-XXVAM2 (Product Code) in our new project design. However, according to the datasheet, the operating temperature range for the E810-XXVAM2 is 0 °C to 105 °C. Since our design requires an industrial-grade component with an operating temperature range of -40 °C to 85 °C, could you please confirm if this part is suitable for our requirements? Alternatively, could you suggest an equivalent package or part number that meets the industrial-grade (-40 °C to 85 °C) specification? Your prompt response on this matter would be greatly appreciated.
Thank You
Niranjan Kumar
Niranjan_1
Hi
I’m following up on the above quarry Could you kindly respond asap? Your response would be greatly appreciated.
Thank You,
Niranjan Kumar
