Ethernet Products
4874 Discussions
RSS could not be enabled on Intel 82599 under Linux 2.6.27.18, driver version 2.0.44.14-NAPI
Has someone ever tried to install an intel 82599(driver version 2.0.44.14-NAPI) under Linux 2.6.27.18?
Intel 82599 driver's readme indicates that MultiQueue is always enabled, but we found it unable to be enabled even by "modprobe ixgbe MQ=1 RSS=1"
Linux will claim the following msgs when the ixgbe driver inserted, firstly MQ enabled automatically, then RSS disabled and finally MQ disabled too caused by ixgbe_init_interrupt_scheme().
ixgbe: Multiple Queue Support Enabled
ixgbe: 0000:05:00.0: ixgbe_check_options: RSS is not supported on this hardware. Disabling RSS.
ixgbe: 0000:05:00.0: ixgbe_init_interrupt_scheme: Multiqueue Disabled: Rx Queue count = 1, Tx Queue count = 1
Related logs attached. Are there any kernel/driver building options we missed at building time?
Thanks in advance if someone can give a reply!!
Following is the log:
mailto:root@localhost root@localhost:~# uname -a
Linux localhost 2.6.27.18-grsec # 1 SMP PREEMPT Fri Jan 29 15:36:22 HKT 2010 x86_64 x86_64 x86_64 GNU/Linux
mailto:root@localhost root@localhost:~# lsmod
Module Size Used by
ixgbe 164016 0
x_tables 27922 2 ip_tables,ip6_tables
ip6_tables 24241 0
ip_tables 22622 0
sctp 196917 2
mailto:root@localhost root@localhost:~# modprobe ixgbe InterruptType=2,2 MQ=1,1 RSS=2,2
ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 2.0.44.14-NAPI
Copyright (c) 1999-2009 Intel Corporation.
ixgbe 0000:05:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
ixgbe 0000:05:00.0: enabling bus mastering
ixgbe 0000:05:00.0: setting latency timer to 64
ixgbe: Interrupt Type set to 2
ixgbe: Receive-Side Scaling (RSS) set to 2
ixgbe: 0000:05:00.0: ixgbe_check_options: Flow Director hash filtering enabled
ixgbe: 0000:05:00.0: ixgbe_check_options: Flow Director allocated 64kB of packet buffer
ixgbe: 0000:05:00.0: ixgbe_check_options: ATR Tx Packet sample rate set to default of 20
ixgbe: eth0: ixgbe_probe: (PCI Express:5.0Gb/s:Width x8) <6>udev: renamed network interface eth0 to fabric1
00:01:af:2e:bf:3e
ixgbe: fabric1: ixgbe_probe: MAC: 2, PHY: 1, PBA No: ffffff-0ff
ADDRCONF(NETDEV_UP): fabric1: link is not ready
ixgbe: fabric1: ixgbe_watchdog_task: NIC Link is Up 10 Gbps, Flow Control: RX/TX
ADDRCONF(NETDEV_CHANGE): fabric1: link becomes ready
ixgbe: fabric1: ixgbe_probe: LRO is disabled
ixgbe: fabric1: ixgbe_probe: HW RSC is enabled
ixgbe: fabric1: ixgbe_probe: Intel(R) 10 Gigabit Network Connection
ixgbe 0000:05:00.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
ixgbe 0000:05:00.1: enabling bus mastering
ixgbe 0000:05:00.1: setting latency timer to 64
ixgbe: 0000:05:00.1: ixgbe_check_options: RSS is not supported on this hardware. Disabling RSS.
ixgbe: 0000:05:00.1: ixgbe_check_options: Flow Director hash filtering enabled
ixgbe: 0000:05:00.1: ixgbe_check_options: Flow Director allocated 64kB of packet buffer
ixgbe: 0000:05:00.1: ixgbe_check_options: ATR Tx Packet sample rate set to default of 20
ixgbe: 0000:05:00.1: ixgbe_init_interrupt_scheme: Multiqueue Disabled: Rx Queue count = 1, Tx Queue count = 1
ixgbe: eth0: ixgbe_probe: (PCI Express:5.0Gb/s:Width x8) 00:01:af:2e:bf:3f
ixgbe: eth0: ixgbe_probe: MAC: 2, PHY: 1, PBA No: ffffff-0ff
ixgbe: eth0: ixgbe_probe: LRO is disabled
ixgbe: eth0: ixgbe_probe: HW RSC is enabled
ixgbe: eth0: ixgbe_probe: Intel(R) 10 Gigabit Network Connection
mailto:root@localhost root@localhost:~# udev: renamed network interface eth0 to fabric2
ADDRCONF(NETDEV_UP): fabric2: link is not ready
fabric1: no IPv6 routers present
mailto:root@localhost root@localhost:~# modinfo ixgbe
filename: /lib/modules/2.6.27.18-grsec/kernel/drivers/net/ixgbe/ixgbe.ko
version: 2.0.44.14-NAPI
license: GPL
description: Intel(R) 10 Gigabit PCI Express Network Driver
author: Intel Corporation, <<a href="mailto:linux.nics@intel.com">linux.nics@intel.com<...
From the readme file of ixgbe driver
RSS - Receive Side Scaling (or multiple queues for receives)
Valid Range: 0 - 16
0 = disables RSS
1 = enables RSS and sets the descriptor queue count to 16 or the number of
online cpus, whichever is less.
2-16 = enables RSS, with 2-16 queues
Default Value: 1
RSS also effects the number of transmit queues allocated on 2.6.23 and
newer kernels with CONFIG_NETDEVICES_MULTIQUEUE set in the kernel .config file.
CONFIG_NETDEVICES_MULTIQUEUE only exists from 2.6.23 to 2.6.26. Other options
enable multiqueue in 2.6.27 and newer kernels."
Does someone know what "Other options" should I enable to make multiqueue work in a 2.6.27.18 kernel? Thanks.
JOHN_R_Intel1
My guess is that the preempt kernel that is being used is not using MSI-X interrupts. If you look in the trace there is an error message that things are being disabled due to the interrupt type. So pick a normal kernel and things should work for you. You can verify if MSI-X interrupts are not being used by doing a 'cat /proc/interrupts'.
John
Thanks so much of your quick reply!!
Maybe my issue is caused by the IRQ routing mode of my Board/Linux? If yes, there must be some kernel options I did not configure properly to enable MSI-X in tylersburg?
Ocean
